I installed zerotier on the new wifi 6 router AXT-1800 the plugin installed fine but its not showing up on my zerotier Users anyone know a fix for this thank you
But it works on its bigger brother
Flint GL-AX1800
Flint GL-AX1800
You mean zerotier user interface? Or you config via terminal?
In the zerotier user interface it dosent show up so i can add it to my user pool.
