I just did the 12V starlink conversion and set up is good. I have the OPAL 1200 travel router and can not
get online with the dish. I have blinking blue light on the side of the router. Everything else looks solid green. I was able to access website and give myself a name and password last week but cant get on now. Do I need to change anything in the router site? Anyone else have these issues and any insight?
I have converted my starlink to 12v using Oleg Kutcov's method of removing two components off the Starlink itself, so I don't need a POE just a dedicated 12v supply. This also means a reduction in potential conflicts (I think?)
I am using a 1300 router but can't get anything to load, it all appears to be connected the correct way and the Starlink is drawing current but I'm getting no internet connection.
I am not technically minded and believed the router would just connect but I'm getting nothing!
Can anyone hold my hand through the process please and make sure I am doing everything correct, step by step if necessary lol
Hi @MisterB1959 Is your issue fixed?
