Any chance of supporting 720P 60Hz? I tried “set custom” with many I could find from that public EDID database but not able to make it work. Only sees “No HDMI signal detected”
glkvm_device_log.zip (95.4 KB)
The device log zip file attached. Thanks.
According to your logs, it appears that the controlled end has never output any resolution. Are you sure the cable is plugged in securely and the controlled end is not powered off or in sleep mode?
I have the exact same issue
Hi, could you please try with the EDID below in costomized EDID.
1280x720@60fps
00 ff ff ff ff ff ff 00 05 e3 77 25 24 00 00 00
01 1e 01 04 a5 37 1f 78 3a 44 55 a9 55 4d 9d 26
0f 50 54 21 08 00 d1 c0 b3 00 95 00 81 80 81 40
81 c0 01 01 01 01 00 19 00 a0 50 d0 15 20 30 20
35 00 29 37 21 00 00 1e 00 00 00 fd 00 32 4c 1e
63 1e 00 0a 20 20 20 20 20 20 00 00 00 fc 00 47
4c 4b 56 4d 0a 20 20 20 20 20 20 20 00 00 00 ff
00 41 48 4c 4c 31 39 41 30 30 30 30 33 36 01 b8
02 03 1e f1 4b 01 03 05 14 04 13 1f 12 02 11 90
23 09 07 07 83 01 00 00 65 03 0c 00 10 00 02 3a
80 18 71 38 2d 40 58 2c 45 00 29 37 21 00 00 1e
01 1d 00 72 51 d0 1e 20 6e 28 55 00 29 37 21 00
00 1e 8c 0a d0 8a 20 e0 2d 10 10 3e 96 00 29 37
21 00 00 18 8c 0a d0 90 20 40 31 20 0c 40 55 00
29 37 21 00 00 18 f0 3c 00 d0 51 a0 35 50 60 88
3a 00 29 37 21 00 00 1c 00 00 00 00 00 00 00 d0
Hi Kyrie,
That customized EDID 1280x720@60fps actually worked! I can see it and remote control it now. Thank you so much!
peiwei
