2021, gl-inet Firmware Firmware 3.211 Beta1, Non alphabetical menue
The well known bug was reported in the past already:
It can be its a bug which are clear and easy to fix.
Looks forward.
Remark:
The full list of found and solved bugs, realisized asked product improvements and possible additional proposal for product improvements can be found on:
This issue has been fixed and will be automatically integrated in tomorrow’s Snapshot version.
Thats sounds great. We will check it.
Test result:
  • Fixed on tested version openwrt-ar750s3.211-1125 (or or before)
THX !!!
