2025-09-20 : Number of SSID? : Fint3 / BE9300
I have several questions and will post them each individually to keep threads clean.
There are 2 SSID’s each for MLO, 6G, 5G and 2.4G
Let’s just discuss the non-MLO capabilities.
I had heard that there are upto 12 SSID’s available. Meaning 4 each for 6G, 5G and 2.4G. I see 2 for each band. Is this maybe a reference to the OpenWRT code base that I think supports 4 SSID per band? Is there a way to get to more SSID’s per band?
MLO is new to me so please forgive the basic nature of my question. The admin GUI has a main and a guest MLO setup with their own SSID id/passwd. What frequencies are being used and shared? Is just for wifi 7 bands or does MLO borrow from the 6,5,2.4 bands?
Thank you.
You can SSH to your Flint3, and execute the following commands:
uci add network device # =cfg150f15
uci set network.@device[-1].type='bridge'
uci set network.@device[-1].name='br-iot'
uci set network.iot=interface
uci set network.iot.proto='static'
uci set network.iot.device='br-iot'
uci set network.iot.ipaddr='192.168.11.1'
uci set network.iot.netmask='255.255.255.0'
uci set dhcp.iot=dhcp
uci set dhcp.iot.interface='iot'
uci set dhcp.iot.start='100'
uci set dhcp.iot.limit='150'
uci set dhcp.iot.leasetime='12h'
uci add firewall zone # =cfg17dc81
uci set firewall.@zone[-1].name='iot'
uci set firewall.@zone[-1].input='REJECT'
uci set firewall.@zone[-1].output='ACCEPT'
uci set firewall.@zone[-1].forward='REJECT'
uci add_list firewall.@zone[-1].network='iot'
uci add firewall forwarding # =cfg18ad58
uci set firewall.@forwarding[-1].src='iot'
uci set firewall.@forwarding[-1].dest='wan'
uci add firewall rule # =cfg1792bd
uci set firewall.@rule[-1].name='Allow-DHCP'
uci add_list firewall.@rule[-1].proto='udp'
uci set firewall.@rule[-1].src='iot'
uci set firewall.@rule[-1].dest_port='67-68'
uci set firewall.@rule[-1].target='ACCEPT'
uci add firewall rule # =cfg1892bd
uci set firewall.@rule[-1].name='Allow-DNS'
uci set firewall.@rule[-1].dest_port='53'
uci set wireless.wifi6g1=wifi-iface
uci set wireless.wifi6g1.device='wifi2'
uci set wireless.wifi6g1.network='iot'
uci set wireless.wifi6g1.mode='ap'
uci set wireless.wifi6g1.ssid='GL-Router-IoT-6G'
uci set wireless.wifi6g1.encryption='ccmp'
uci set wireless.wifi6g1.sae_pwe='1'
uci set wireless.wifi6g1.key='goodlife'
uci set wireless.wifi6g1.wds='1'
uci set wireless.wifi6g1.isolate='0'
uci set wireless.wifi6g1.hidden='0'
uci set wireless.wifi6g1.ifname='wlan24'
uci set wireless.wifi6g1.ieee80211k='1'
uci set wireless.wifi6g1.bss_transition='1'
uci set wireless.wifi6g1.sae='1'
uci set wireless.wifi6g1.acs_6g_only_psc='1'
uci set wireless.wifi6g1.disabled='0'
uci set wireless.wifi6g2=wifi-iface
uci set wireless.wifi6g2.device='wifi2'
uci set wireless.wifi6g2.network='iot'
uci set wireless.wifi6g2.mode='ap'
uci set wireless.wifi6g2.ssid='GL Router-Custom-6G'
uci set wireless.wifi6g2.encryption='ccmp'
uci set wireless.wifi6g2.sae_pwe='1'
uci set wireless.wifi6g2.key='goodlife'
uci set wireless.wifi6g2.wds='1'
uci set wireless.wifi6g2.isolate='0'
uci set wireless.wifi6g2.hidden='0'
uci set wireless.wifi6g2.ifname='wlan25'
uci set wireless.wifi6g2.ieee80211k='1'
uci set wireless.wifi6g2.bss_transition='1'
uci set wireless.wifi6g2.sae='1'
uci set wireless.wifi6g2.acs_6g_only_psc='1'
uci set wireless.wifi6g2.disabled='0'
uci set wireless.wifi5g1=wifi-iface
uci set wireless.wifi5g1.device='wifi1'
uci set wireless.wifi5g1.network='iot'
uci set wireless.wifi5g1.mode='ap'
uci set wireless.wifi5g1.ssid='GL Router-IoT-5G'
uci set wireless.wifi5g1.encryption='psk2+ccmp'
uci set wireless.wifi5g1.key='goodlife'
uci set wireless.wifi5g1.wds='1'
uci set wireless.wifi5g1.isolate='0'
uci set wireless.wifi5g1.hidden='0'
uci set wireless.wifi5g1.ifname='wlan14'
uci set wireless.wifi5g1.ieee80211k='1'
uci set wireless.wifi5g1.bss_transition='1'
uci set wireless.wifi5g1.sae='0'
uci set wireless.wifi5g1.disabled='0'
uci set wireless.wifi5g2=wifi-iface
uci set wireless.wifi5g2.device='wifi1'
uci set wireless.wifi5g2.network='iot'
uci set wireless.wifi5g2.mode='ap'
uci set wireless.wifi5g2.ssid='GL Router-Custom-5G'
uci set wireless.wifi5g2.encryption='psk2+ccmp'
uci set wireless.wifi5g2.key='goodlife'
uci set wireless.wifi5g2.wds='1'
uci set wireless.wifi5g2.isolate='0'
uci set wireless.wifi5g2.hidden='0'
uci set wireless.wifi5g2.ifname='wlan15'
uci set wireless.wifi5g2.ieee80211k='1'
uci set wireless.wifi5g2.bss_transition='1'
uci set wireless.wifi5g2.sae='0'
uci set wireless.wifi5g2.disabled='0'
uci set wireless.wifi2g1=wifi-iface
uci set wireless.wifi2g1.device='wifi0'
uci set wireless.wifi2g1.network='iot'
uci set wireless.wifi2g1.mode='ap'
uci set wireless.wifi2g1.ssid='GL Router-IoT-2.4G'
uci set wireless.wifi2g1.encryption='psk2+ccmp'
uci set wireless.wifi2g1.key='goodlife'
uci set wireless.wifi2g1.wds='1'
uci set wireless.wifi2g1.isolate='0'
uci set wireless.wifi2g1.hidden='0'
uci set wireless.wifi2g1.ifname='wlan04'
uci set wireless.wifi2g1.ieee80211k='1'
uci set wireless.wifi2g1.bss_transition='1'
uci set wireless.wifi2g1.sae='0'
uci set wireless.wifi2g1.disabled='0'
uci set wireless.wifi2g2=wifi-iface
uci set wireless.wifi2g2.device='wifi0'
uci set wireless.wifi2g2.network='iot'
uci set wireless.wifi2g2.mode='ap'
uci set wireless.wifi2g2.ssid='GL Router-Custom-2.4G'
uci set wireless.wifi2g2.encryption='psk2+ccmp'
uci set wireless.wifi2g2.key='goodlife'
uci set wireless.wifi2g2.wds='1'
uci set wireless.wifi2g2.isolate='0'
uci set wireless.wifi2g2.hidden='0'
uci set wireless.wifi2g2.ifname='wlan05'
uci set wireless.wifi2g2.ieee80211k='1'
uci set wireless.wifi2g2.bss_transition='1'
uci set wireless.wifi2g2.sae='0'
uci set wireless.wifi2g2.disabled='0'
uci commit wireless
reboot
Will new add 2 x [2.4GHz Radio + 5GHz Radio + 6GHz Radio], new firewall zone is iot, subnet is 192.168.11.1, password is goodlife
Do I execute the commands line by line? or can 1 shot “copy all and paste all” into SSH?
would the interface be named iot on the GUI? (in small cap)
You can copy them all and execute at once in router SSH terminal.
In the Client list of the GL GUI, the custom-added bridge and radio connected clients will not be displayed, but can be checked in Luci's DHCP lease.
