2G LED configuration on AR750s
Hello good folks!
How do I configure the 2G LED to be on when the 2.4GHz Wifi is on and off when the 2.4GHz Wifi is off?
Using OpenWrt 19.07.4
Thanks!
You should go to luci->system and find led config.
Add one config and use netdev as trigger, find the correct led. You may also set up other parameters and it should be easy.
