3.105 on GL-AR750 - some devices doesn't reconnect on reboot
I am trying firmware 3.105 on my GL-AR750 and I am experiencing this strange behavior: if I reboot my device from UI, Luci or even after a power loss, some wifi devices doesn’t automatically reconnect after boot. This problem is persistent with 2 smart bulbs that I have (Xiaomi Mi smart bulb): they never automatically reconnect. It sometimes happens with my security camera also. Finally, even the wifi on my W10 PC doesnt automatically reconnect: I have to manually click on the “connect” button everytime even if the “connect automatically” option is checked. I never exeperienced this behaviour on 3.027 firmware: every wifi device never missed a reconnection on reboot.
I will try to verify your question.
Please help provide detailed log information to locate the problem.
Thanks a lot. Here’s the log.
In this case, my PC reconnected autmatically, but slower compared to firmware 3.027, a considerable amount of time after the ui reboot loading bar was at 100%.
No trace of my smart bulbs after reboot (192.168.8.150 & 192.168.8.227) like if they don’t exist.
They are in fact in the “offline device” list in the UI.
Just re-tested and everything is ok with firmware 3.027.
Sat Oct 17 15:55:24 2020 kern.notice kernel: [    0.000000] Linux version 4.9.120 (cc@cc-ubuntu1604) (gcc version 7.3.0 (OpenWrt GCC 7.3.0 r7258-5eb055306f) ) #0 Thu Aug 16 07:51:15 2018
Sat Oct 17 15:55:24 2020 kern.debug kernel: [    0.000000] MyLoader: sysp=6eff6c0f, boardp=aebe663d, parts=febb40f5
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.000000] bootconsole [early0] enabled
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.000000] CPU0 revision is: 00019374 (MIPS 24Kc)
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.000000] SoC: Qualcomm Atheros QCA9533 ver 2 rev 0
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.000000] Determined physical RAM map:
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.000000]  memory: 08000000 @ 00000000 (usable)
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.000000] Initrd not found or empty - disabling initrd
Sat Oct 17 15:55:24 2020 kern.warn kernel: [    0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Sat Oct 17 15:55:24 2020 kern.warn kernel: [    0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.000000] Zone ranges:
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.000000]   Normal   [mem 0x0000000000000000-0x0000000007ffffff]
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.000000] Movable zone start for each node
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.000000] Early memory node ranges
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.000000]   node   0: [mem 0x0000000000000000-0x0000000007ffffff]
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
Sat Oct 17 15:55:24 2020 kern.debug kernel: [    0.000000] On node 0 totalpages: 32768
Sat Oct 17 15:55:24 2020 kern.debug kernel: [    0.000000] free_area_init_node: node 0, pgdat 804dd0f4, node_mem_map 81000020
Sat Oct 17 15:55:24 2020 kern.debug kernel: [    0.000000]   Normal zone: 256 pages used for memmap
Sat Oct 17 15:55:24 2020 kern.debug kernel: [    0.000000]   Normal zone: 0 pages reserved
Sat Oct 17 15:55:24 2020 kern.debug kernel: [    0.000000]   Normal zone: 32768 pages, LIFO batch:7
Sat Oct 17 15:55:24 2020 kern.debug kernel: [    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Sat Oct 17 15:55:24 2020 kern.debug kernel: [    0.000000] pcpu-alloc: [0] 0
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
Sat Oct 17 15:55:24 2020 kern.notice kernel: [    0.000000] Kernel command line:  board=GL-AR750 mtdparts=spi0.0:256k(u-boot)ro,64k(u-boot-env),64k(art)ro,-(firmware) console=ttyS0,115200 rootfstype=squashfs noinitrd
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.000000] Writing ErrCtl register=00000000
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.000000] Readback ErrCtl register=00000000
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.000000] Memory: 124352K/131072K available (3533K kernel code, 182K rwdata, 884K rodata, 320K init, 220K bss, 6720K reserved, 0K cma-reserved)
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.000000] NR_IRQS:51
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.000000] Clocks: CPU:650.000MHz, DDR:597.094MHz, AHB:216.666MHz, Ref:25.000MHz
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 5880801374 ns
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.000008] sched_clock: 32 bits at 325MHz, resolution 3ns, wraps every 6607641598ns
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.008242] Calibrating delay loop... 432.53 BogoMIPS (lpj=2162688)
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.071099] pid_max: default: 32768 minimum: 301
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.076077] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.083055] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.093223] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.103612] futex hash table entries: 256 (order: -1, 3072 bytes)
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.111240] NET: Registered protocol family 16
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.117424] MIPS: machine is GL.iNet GL-AR750
Sat Oct 17 15:55:24 2020 kern.warn kernel: [    0.604493] registering PCI controller with io_map_base unset
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.627634] usbcore: registered new interface driver usbfs
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.633536] usbcore: registered new interface driver hub
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.639197] usbcore: registered new device driver usb
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.644740] i2c-gpio i2c-gpio.0: using pins 17 (SDA) and 16 (SCL)
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.651394] PCI host bridge to bus 0000:00
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.655752] pci_bus 0000:00: root bus resource [mem 0x10000000-0x11ffffff]
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.662996] pci_bus 0000:00: root bus resource [io  0x0000]
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.668870] pci_bus 0000:00: root bus resource [??? 0x00000000 flags 0x0]
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.676019] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
Sat Oct 17 15:55:24 2020 kern.debug kernel: [    0.684406] pci 0000:00:00.0: [168c:0050] type 00 class 0x028000
Sat Oct 17 15:55:24 2020 kern.err kernel: [    0.684415] pci 0000:00:00.0: invalid calibration data
Sat Oct 17 15:55:24 2020 kern.debug kernel: [    0.689855] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit]
Sat Oct 17 15:55:24 2020 kern.debug kernel: [    0.689908] pci 0000:00:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
Sat Oct 17 15:55:24 2020 kern.debug kernel: [    0.689977] pci 0000:00:00.0: supports D1
Sat Oct 17 15:55:24 2020 kern.debug kernel: [    0.689986] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
Sat Oct 17 15:55:24 2020 kern.debug kernel: [    0.690176] pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to 00
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.690203] pci 0000:00:00.0: BAR 0: assigned [mem 0x10000000-0x101fffff 64bit]
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.697957] pci 0000:00:00.0: BAR 6: assigned [mem 0x10200000-0x1020ffff pref]
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.705571] pci 0000:00:00.0: using irq 40 for pin 1
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.714598] clocksource: Switched to clocksource MIPS
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.721000] NET: Registered protocol family 2
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.726500] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.733859] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.740612] TCP: Hash tables configured (established 1024 bind 1024)
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.747421] UDP hash table entries: 256 (order: 0, 4096 bytes)
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.753587] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.760471] NET: Registered protocol family 1
Sat Oct 17 15:55:24 2020 kern.debug kernel: [    0.765140] PCI: CLS 0 bytes, default 32
Sat Oct 17 15:55:24 2020 kern.warn kernel: [    0.767795] Crashlog allocated RAM at address 0x3f00000
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.774339] workingset: timestamp_bits=30 max_order=15 bucket_order=0
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.788123] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.794266] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.813480] io scheduler noop registered
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.817670] io scheduler deadline registered (default)
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.823483] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.832649] console [ttyS0] disabled
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.856561] serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11, base_baud = 1562500) is a 16550A
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.865661] console [ttyS0] enabled
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.873204] bootconsole [early0] disabled
Sat Oct 17 15:55:24 2020 kern.warn kernel: [    0.887702] m25p80 spi0.0: found w25q128, expected m25p80
Sat Oct 17 15:55:24 2020 kern.info kernel: [    0.902942] m25p80 spi0.0: w25q128 (16384 Kbytes)
Sat Oct 17 15:55:24 2020 kern.notice kernel: [    0.907841] 4 cmdlinepart partitions found on MTD device spi0.0
Sat Oct 17 15:55:24 2020 kern.notice kernel: [    0.913955] Creating 4 MTD partitions on "spi0.0":
Sat Oct 17 15:55:24 2020 kern.notice kernel: [    0.918925] 0x000000000000-0x000000040000 : "u-boot"
Sat Oct 17 15:55:24 2020 kern.notice kernel: [    0.925937] 0x000000040000-0x000000050000 : "u-boot-env"
Sat Oct 17 15:55:24 2020 kern.notice kernel: [    0.933324] 0x000000050000-0x000000060000 : "art"
Sat Oct 17 15:55:24 2020 kern.notice kernel: [    0.940160] 0x000000060000-0x000001000000 : "firmware"
Sat Oct 17 15:55:24 2020 kern.notice kernel: [    0.993622] 2 uimage-fw partitions found on MTD device firmware
Sat Oct 17 15:55:24 2020 kern.notice kernel: [    0.999788] 0x000000060000-0x0000001e0000 : "kernel"
Sat Oct 17 15:55:24 2020 kern.notice kernel: [    1.006280] 0x0000001e0000-0x000001000000 : "rootfs"
Sat Oct 17 15:55:24 2020 kern.notice kernel: [    1.012970] mtd: device 5 (rootfs) set to be root filesystem
Sat Oct 17 15:55:24 2020 kern.notice kernel: [    1.019372] 1 squashfs-split partitions found on MTD device rootfs
Sat Oct 17 15:55:24 2020 kern.notice kernel: [    1.025815] 0x000000d10000-0x000001000000 : "rootfs_data"
Sat Oct 17 15:55:24 2020 kern.info kernel: [    1.034136] libphy: Fixed MDIO Bus: probed
Sat Oct 17 15:55:24 2020 kern.info kernel: [    1.061182] libphy: ag71xx_mdio: probed
Sat Oct 17 15:55:24 2020 kern.info kernel: [    1.697532] ag71xx ag71xx.0: connected to PHY at ag71xx-mdio.1:04 [uid=004dd042, driver=Generic PHY]
Sat Oct 17 15:55:24 2020 kern.info kernel: [    1.707645] eth0: Atheros AG71xx at 0xb9000000, irq 4, mode:MII
Sat Oct 17 15:55:24 2020 kern.info kernel: [    2.337143] ag71xx-mdio.1: Found an AR934X built-in switch
Sat Oct 17 15:55:24 2020 kern.info kernel: [    2.390452] eth1: Atheros AG71xx at 0xba000000, irq 5, mode:GMII
Sat Oct 17 15:55:24 2020 kern.info kernel: [    2.396983] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Sat Oct 17 15:55:24 2020 kern.info kernel: [    2.403724] ehci-pci: EHCI PCI platform driver
Sat Oct 17 15:55:24 2020 kern.info kernel: [    2.408519] usbcore: registered new interface driver usbtest
Sat Oct 17 15:55:24 2020 kern.info kernel: [    2.414418] usbcore: registered new interface driver usb_ehset_test
Sat Oct 17 15:55:24 2020 kern.info kernel: [    2.420982] usbcore: registered new interface driver lvs
Sat Oct 17 15:55:24 2020 kern.info kernel: [    2.427949] NET: Registered protocol family 10
Sat Oct 17 15:55:24 2020 kern.info kernel: [    2.436944] NET: Registered protocol family 17
Sat Oct 17 15:55:24 2020 kern.info kernel: [    2.441593] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Sat Oct 17 15:55:24 2020 kern.info kernel: [    2.455113] 8021q: 802.1Q VLAN Support v1.8
Sat Oct 17 15:55:24 2020 kern.info kernel: [    2.461153] hctosys: unable to open rtc device (rtc0)
Sat Oct 17 15:55:24 2020 kern.info kernel: [    2.473470] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
Sat Oct 17 15:55:24 2020 kern.info kernel: [    2.482540] Freeing unused kernel memory: 320K
Sat Oct 17 15:55:24 2020 kern.warn kernel: [    2.487163] This architecture does not have kernel memory protection.
Sat Oct 17 15:55:24 2020 kern.notice kernel: [    2.564604] random: fast init done
Sat Oct 17 15:55:24 2020 user.info kernel: [    3.369635] init: Console is alive
Sat Oct 17 15:55:24 2020 user.info kernel: [    3.373358] init: - watchdog -
Sat Oct 17 15:55:24 2020 user.info kernel: [    6.214805] kmodloader: loading kernel modules from /etc/modules-boot.d/*
Sat Oct 17 15:55:24 2020 kern.info kernel: [    6.616100] exFAT: Version 1.2.9
Sat Oct 17 15:55:24 2020 kern.notice kernel: [    6.657785] SCSI subsystem initialized
Sat Oct 17 15:55:24 2020 kern.info kernel: [    6.666992] ehci-platform: EHCI generic platform driver
Sat Oct 17 15:55:24 2020 kern.info kernel: [    6.672502] ehci-platform ehci-platform: EHCI Host Controller
Sat Oct 17 15:55:24 2020 kern.info kernel: [    6.678677] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
Sat Oct 17 15:55:24 2020 kern.info kernel: [    6.689003] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
Sat Oct 17 15:55:24 2020 kern.info kernel: [    6.724637] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
Sat Oct 17 15:55:24 2020 kern.info kernel: [    6.731322] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Sat Oct 17 15:55:24 2020 kern.info kernel: [    6.738366] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Sat Oct 17 15:55:24 2020 kern.info kernel: [    6.745840] usb usb1: Product: EHCI Host Controller
Sat Oct 17 15:55:24 2020 kern.info kernel: [    6.750878] usb usb1: Manufacturer: Linux 4.9.120 ehci_hcd
Sat Oct 17 15:55:24 2020 kern.info kernel: [    6.756556] usb usb1: SerialNumber: ehci-platform
Sat Oct 17 15:55:24 2020 kern.info kernel: [    6.762216] hub 1-0:1.0: USB hub found
Sat Oct 17 15:55:24 2020 kern.info kernel: [    6.766399] hub 1-0:1.0: 1 port detected
Sat Oct 17 15:55:24 2020 kern.info kernel: [    6.773510] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Sat Oct 17 15:55:24 2020 kern.info kernel: [    6.781447] ohci-platform: OHCI generic platform driver
Sat Oct 17 15:55:24 2020 kern.info kernel: [    6.789467] uhci_hcd: USB Universal Host Controller Interface driver
Sat Oct 17 15:55:24 2020 kern.info kernel: [    6.800603] usbcore: registered new interface driver usb-storage
Sat Oct 17 15:55:24 2020 kern.info kernel: [    6.808904] usbcore: registered new interface driver uas
Sat Oct 17 15:55:24 2020 user.info kernel: [    6.815152] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Sat Oct 17 15:55:24 2020 user.info kernel: [    6.833056] init: - preinit -
Sat Oct 17 15:55:24 2020 kern.info kernel: [    7.556152] usb 1-1: new high-speed USB device number 2 using ehci-platform
Sat Oct 17 15:55:24 2020 kern.info kernel: [    7.809073] usb 1-1: New USB device found, idVendor=05e3, idProduct=0618
Sat Oct 17 15:55:24 2020 kern.info kernel: [    7.816061] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Sat Oct 17 15:55:24 2020 kern.info kernel: [    7.823440] usb 1-1: Product: USB2.0 Hub
Sat Oct 17 15:55:24 2020 kern.notice kernel: [    7.828478] random: procd: uninitialized urandom read (4 bytes read)
Sat Oct 17 15:55:24 2020 kern.info kernel: [    7.842574] hub 1-1:1.0: USB hub found
Sat Oct 17 15:55:24 2020 kern.info kernel: [    7.854678] hub 1-1:1.0: 4 ports detected
Sat Oct 17 15:55:24 2020 kern.info kernel: [    8.262856] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
Sat Oct 17 15:55:24 2020 kern.info kernel: [    8.307026] usb 1-1.1: new high-speed USB device number 3 using ehci-platform
Sat Oct 17 15:55:24 2020 kern.info kernel: [    8.469024] usb 1-1.1: New USB device found, idVendor=05e3, idProduct=0752
Sat Oct 17 15:55:24 2020 kern.info kernel: [    8.476168] usb 1-1.1: New USB device strings: Mfr=3, Product=4, SerialNumber=0
Sat Oct 17 15:55:24 2020 kern.info kernel: [    8.483725] usb 1-1.1: Product: USB Storage
Sat Oct 17 15:55:24 2020 kern.info kernel: [    8.488057] usb 1-1.1: Manufacturer: Generic
Sat Oct 17 15:55:24 2020 kern.info kernel: [    8.493799] usb-storage 1-1.1:1.0: USB Mass Storage device detected
Sat Oct 17 15:55:24 2020 kern.info kernel: [    8.501116] scsi host0: usb-storage 1-1.1:1.0
Sat Oct 17 15:55:24 2020 kern.notice kernel: [    9.556407] scsi 0:0:0:0: Direct-Access     Generic  STORAGE DEVICE   0233 PQ: 0 ANSI: 0
Sat Oct 17 15:55:24 2020 kern.notice kernel: [    9.722693] sd 0:0:0:0: [sda] 121610240 512-byte logical blocks: (62.3 GB/58.0 GiB)
Sat Oct 17 15:55:24 2020 kern.notice kernel: [    9.731803] sd 0:0:0:0: [sda] Write Protect is off
Sat Oct 17 15:55:24 2020 kern.debug kernel: [    9.736819] sd 0:0:0:0: [sda] Mode Sense: 0b 00 00 08
Sat Oct 17 15:55:24 2020 kern.err kernel: [    9.738053] sd 0:0:0:0: [sda] No Caching mode page found
Sat Oct 17 15:55:24 2020 kern.err kernel: [    9.743548] sd 0:0:0:0: [sda] Assuming drive cache: write through
Sat Oct 17 15:55:24 2020 kern.info kernel: [    9.756203]  sda: sda1
Sat Oct 17 15:55:24 2020 kern.notice kernel: [    9.763062] sd 0:0:0:0: [sda] Attached SCSI removable disk
Sat Oct 17 15:55:24 2020 kern.info kernel: [    9.896038] eth1: link up (1000Mbps/Full duplex)
Sat Oct 17 15:55:24 2020 kern.info kernel: [    9.900830] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
Sat Oct 17 15:55:24 2020 kern.notice kernel: [   11.611202] jffs2: notice: (480) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
Sat Oct 17 15:55:24 2020 user.info kernel: [   11.630622] mount_root: switching to jffs2 overlay
Sat Oct 17 15:55:24 2020 user.warn kernel: [   11.710936] urandom-seed: Seeding with /etc/urandom.seed
Sat Oct 17 15:55:24 2020 kern.info kernel: [   11.890066] eth1: link down
Sat Oct 17 15:55:24 2020 user.info kernel: [   11.903999] procd: - early -
Sat Oct 17 15:55:24 2020 user.info kernel: [   11.907778] procd: - watchdog -
Sat Oct 17 15:55:24 2020 user.info kernel: [   12.611041] procd: - watchdog -
Sat Oct 17 15:55:24 2020 user.info kernel: [   12.614523] procd: - ubus -
Sat Oct 17 15:55:24 2020 kern.notice kernel: [   12.873470] random: ubusd: uninitialized urandom read (4 bytes read)
Sat Oct 17 15:55:24 2020 kern.notice kernel: [   13.073291] random: ubusd: uninitialized urandom read (4 bytes read)
Sat Oct 17 15:55:24 2020 kern.notice kernel: [   13.080341] random: ubusd: uninitialized urandom read (4 bytes read)
Sat Oct 17 15:55:24 2020 user.info kernel: [   13.093477] procd: - init -
Sat Oct 17 15:55:24 2020 user.info kernel: [   15.750663] kmodloader: loading kernel modules from /etc/modules.d/*
Sat Oct 17 15:55:24 2020 kern.info kernel: [   16.070669] ntfs: driver 2.1.32 [Flags: R/O MODULE].
Sat Oct 17 15:55:24 2020 kern.info kernel: [   16.106888] tun: Universal TUN/TAP device driver, 1.6
Sat Oct 17 15:55:24 2020 kern.info kernel: [   16.112113] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
Sat Oct 17 15:55:24 2020 kern.info kernel: [   16.153312] ip6_tables: (C) 2000-2006 Netfilter Core Team
Sat Oct 17 15:55:24 2020 kern.info kernel: [   16.179580] Netfilter messages via NETLINK v0.30.
Sat Oct 17 15:55:24 2020 kern.info kernel: [   16.198121] ip_set: protocol 6
Sat Oct 17 15:55:24 2020 kern.info kernel: [   16.306155] u32 classifier
Sat Oct 17 15:55:24 2020 kern.info kernel: [   16.308963]     input device check on
Sat Oct 17 15:55:24 2020 kern.info kernel: [   16.312742]     Actions configured
Sat Oct 17 15:55:24 2020 kern.info kernel: [   16.337396] Mirror/redirect action on
Sat Oct 17 15:55:24 2020 kern.info kernel: [   16.353366] nf_conntrack version 0.5.0 (2048 buckets, 8192 max)
Sat Oct 17 15:55:24 2020 kern.info kernel: [   16.442777] fuse init (API version 7.26)
Sat Oct 17 15:55:24 2020 kern.info kernel: [   16.473696] usbcore: registered new interface driver cdc_acm
Sat Oct 17 15:55:24 2020 kern.info kernel: [   16.479605] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Sat Oct 17 15:55:24 2020 kern.info kernel: [   16.516282] usbcore: registered new interface driver cdc_wdm
Sat Oct 17 15:55:24 2020 kern.info kernel: [   16.534564] Loading modules backported from Linux version wt-2017-11-01-0-gfe248fc2c180
Sat Oct 17 15:55:24 2020 kern.info kernel: [   16.542893] Backport generated by backports.git v4.14-rc2-1-31-g86cf0e5d
Sat Oct 17 15:55:24 2020 kern.info kernel: [   16.599446] Ebtables v2.0 registered
Sat Oct 17 15:55:24 2020 kern.info kernel: [   16.607199] ip_tables: (C) 2000-2006 Netfilter Core Team
Sat Oct 17 15:55:24 2020 kern.info kernel: [   16.625364] usbcore: registered new interface driver ipheth
Sat Oct 17 15:55:24 2020 kern.info kernel: [   16.820255] ctnetlink v0.93: registering with nfnetlink.
Sat Oct 17 15:55:24 2020 kern.info kernel: [   17.090278] usbcore: registered new interface driver usbserial
Sat Oct 17 15:55:24 2020 kern.info kernel: [   17.096474] usbcore: registered new interface driver usbserial_generic
Sat Oct 17 15:55:24 2020 kern.info kernel: [   17.103294] usbserial: USB Serial support registered for generic
Sat Oct 17 15:55:24 2020 kern.info kernel: [   17.144967] wireguard: WireGuard 0.0.20191012 loaded. See www.wireguard.com for information.
Sat Oct 17 15:55:24 2020 kern.info kernel: [   17.153686] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
Sat Oct 17 15:55:24 2020 kern.info kernel: [   17.288760] xt_time: kernel timezone is -0000
Sat Oct 17 15:55:24 2020 kern.info kernel: [   17.306757] usbcore: registered new interface driver cdc_ether
Sat Oct 17 15:55:24 2020 kern.info kernel: [   17.318194] usbcore: registered new interface driver cdc_ncm
Sat Oct 17 15:55:24 2020 kern.info kernel: [   17.437761] usbcore: registered new interface driver cp210x
Sat Oct 17 15:55:24 2020 kern.info kernel: [   17.443599] usbserial: USB Serial support registered for cp210x
Sat Oct 17 15:55:24 2020 kern.info kernel: [   17.494494] usbcore: registered new interface driver huawei_cdc_ncm
Sat Oct 17 15:55:24 2020 kern.info kernel: [   17.688438] PPP generic driver version 2.4.2
Sat Oct 17 15:55:24 2020 kern.info kernel: [   17.728943] PPP MPPE Compression module registered
Sat Oct 17 15:55:24 2020 kern.info kernel: [   17.747522] NET: Registered protocol family 24
Sat Oct 17 15:55:24 2020 kern.info kernel: [   17.765915] usbcore: registered new interface driver qmi_wwan
Sat Oct 17 15:55:24 2020 kern.info kernel: [   17.794832] usbcore: registered new interface driver rndis_host
Sat Oct 17 15:55:24 2020 kern.info kernel: [   17.865465] usbcore: registered new interface driver sierra
Sat Oct 17 15:55:24 2020 kern.info kernel: [   17.871310] usbserial: USB Serial support registered for Sierra USB modem
Sat Oct 17 15:55:24 2020 kern.info kernel: [   17.918774] usbcore: registered new interface driver sierra_net
Sat Oct 17 15:55:24 2020 kern.warn kernel: [   18.149032] PCI: Enabling device 0000:00:00.0 (0000 -> 0002)
Sat Oct 17 15:55:24 2020 kern.info kernel: [   18.157161] ath10k_pci 0000:00:00.0: pci irq legacy oper_irq_mode 1 irq_mode 0 reset_mode 0
Sat Oct 17 15:55:24 2020 kern.warn kernel: [   18.505157] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:00:00.0.bin failed with error -2
Sat Oct 17 15:55:24 2020 kern.warn kernel: [   18.516250] ath10k_pci 0000:00:00.0: Falling back to user helper
Sat Oct 17 15:55:24 2020 kern.err kernel: [   35.904523] firmware ath10k!pre-cal-pci-0000:00:00.0.bin: firmware_loading_store: map pages failed
Sat Oct 17 15:55:24 2020 kern.warn kernel: [   35.915488] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA9887/hw1.0/firmware-6.bin failed with error -2
Sat Oct 17 15:55:24 2020 kern.warn kernel: [   35.926591] ath10k_pci 0000:00:00.0: Falling back to user helper
Sat Oct 17 15:55:24 2020 kern.err kernel: [   36.078535] firmware ath10k!QCA9887!hw1.0!firmware-6.bin: firmware_loading_store: map pages failed
Sat Oct 17 15:55:24 2020 kern.info kernel: [   36.289052] ath10k_pci 0000:00:00.0: qca9887 hw1.0 target 0x4100016d chip_id 0x004000ff sub 0000:0000
Sat Oct 17 15:55:24 2020 kern.info kernel: [   36.298638] ath10k_pci 0000:00:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
Sat Oct 17 15:55:24 2020 kern.info kernel: [   36.312558] ath10k_pci 0000:00:00.0: firmware ver 10.2.4-1.0-00033 api 5 features no-p2p,ignore-otp,skip-clock-init,mfp,allows-mesh-bcast crc32 c232a0c3
Sat Oct 17 15:55:24 2020 kern.warn kernel: [   36.359439] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA9887/hw1.0/board-2.bin failed with error -2
Sat Oct 17 15:55:24 2020 kern.warn kernel: [   36.370241] ath10k_pci 0000:00:00.0: Falling back to user helper
Sat Oct 17 15:55:24 2020 kern.err kernel: [   36.449488] firmware ath10k!QCA9887!hw1.0!board-2.bin: firmware_loading_store: map pages failed
Sat Oct 17 15:55:24 2020 kern.info kernel: [   36.476767] ath10k_pci 0000:00:00.0: board_file api 1 bmi_id N/A crc32 546cca0d
Sat Oct 17 15:55:24 2020 kern.info kernel: [   37.541797] ath10k_pci 0000:00:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal file max-sta 128 raw 0 hwcrypto 1
Sat Oct 17 15:55:24 2020 kern.debug kernel: [   37.686155] ath: EEPROM regdomain: 0x0
Sat Oct 17 15:55:24 2020 kern.debug kernel: [   37.686164] ath: EEPROM indicates default country code should be used
Sat Oct 17 15:55:24 2020 kern.debug kernel: [   37.686167] ath: doing EEPROM country->regdmn map search
Sat Oct 17 15:55:24 2020 kern.debug kernel: [   37.686178] ath: country maps to regdmn code: 0x3a
Sat Oct 17 15:55:24 2020 kern.debug kernel: [   37.686183] ath: Country alpha2 being used: US
Sat Oct 17 15:55:24 2020 kern.debug kernel: [   37.686186] ath: Regpair used: 0x3a
Sat Oct 17 15:55:24 2020 kern.info kernel: [   37.791732] usbcore: registered new interface driver option
Sat Oct 17 15:55:24 2020 kern.info kernel: [   37.797648] usbserial: USB Serial support registered for GSM modem (1-port)
Sat Oct 17 15:55:24 2020 kern.info kernel: [   37.825340] usbcore: registered new interface driver rt2800usb
Sat Oct 17 15:55:24 2020 kern.debug kernel: [   37.919618] ath: EEPROM regdomain: 0x0
Sat Oct 17 15:55:24 2020 kern.debug kernel: [   37.919627] ath: EEPROM indicates default country code should be used
Sat Oct 17 15:55:24 2020 kern.debug kernel: [   37.919630] ath: doing EEPROM country->regdmn map search
Sat Oct 17 15:55:24 2020 kern.debug kernel: [   37.919644] ath: country maps to regdmn code: 0x3a
Sat Oct 17 15:55:24 2020 kern.debug kernel: [   37.919649] ath: Country alpha2 being used: US
Sat Oct 17 15:55:24 2020 kern.debug kernel: [   37.919653] ath: Regpair used: 0x3a
Sat Oct 17 15:55:24 2020 kern.debug kernel: [   37.930474] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
Sat Oct 17 15:55:24 2020 kern.info kernel: [   37.934562] ieee80211 phy1: Atheros AR9531 Rev:2 mem=0xb8100000, irq=47
Sat Oct 17 15:55:24 2020 user.info kernel: [   37.945858] kmodloader: done loading kernel modules from /etc/modules.d/*
Sat Oct 17 15:55:25 2020 daemon.notice procd: /etc/rc.d/S18firewall_gl: uci: Entry not found
Sat Oct 17 15:55:27 2020 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Sat Oct 17 15:55:27 2020 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Sat Oct 17 15:55:28 2020 daemon.info dnsmasq[1475]: started, version 2.80test2 cachesize 150
Sat Oct 17 15:55:28 2020 daemon.info dnsmasq[1475]: DNS service limited to local subnets
Sat Oct 17 15:55:28 2020 daemon.info dnsmasq[1475]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Sat Oct 17 15:55:28 2020 daemon.info dnsmasq[1475]: using local addresses only for domain test
Sat Oct 17 15:55:28 2020 daemon.info dnsmasq[1475]: using local addresses only for domain onion
Sat Oct 17 15:55:28 2020 daemon.info dnsmasq[1475]: using local addresses only for domain localhost
Sat Oct 17 15:55:28 2020 daemon.info dnsmasq[1475]: using local addresses only for domain invalid
Sat Oct 17 15:55:28 2020 daemon.info dnsmasq[1475]: using local addresses only for domain bind
Sat Oct 17 15:55:28 2020 daemon.info dnsmasq[1475]: using local addresses only for domain lan
Sat Oct 17 15:55:28 2020 daemon.warn dnsmasq[1475]: no servers found in /tmp/resolv.conf.auto, will retry
Sat Oct 17 15:55:28 2020 daemon.info dnsmasq[1475]: read /etc/hosts - 4 addresses
Sat Oct 17 15:55:28 2020 daemon.info dnsmasq[1475]: read /tmp/hosts/dhcp.cfg01411c - 1 addresses
Sat Oct 17 15:55:32 2020 user.notice : Added device handler type: tunnel
Sat Oct 17 15:55:32 2020 user.notice : Added device handler type: Network device
Sat Oct 17 15:55:32 2020 user.notice : Added device handler type: bridge
Sat Oct 17 15:55:32 2020 user.notice : Added device handler type: veth
Sat Oct 17 15:55:32 2020 user.notice : Added device handler type: macvlan
Sat Oct 17 15:55:32 2020 user.notice : Added device handler type: 8021ad
Sat Oct 17 15:55:32 2020 user.notice : Added device handler type: 8021q
Sat Oct 17 15:55:33 2020 daemon.notice procd: /etc/rc.d/S21initswitch: uci: Entry not found
Sat Oct 17 15:55:34 2020 daemon.notice procd: /etc/rc.d/S30gl_ssids: uci: Entry not found
Sat Oct 17 15:55:34 2020 daemon.notice procd: /etc/init.d/gl_ssids: uci: Entry not found
Sat Oct 17 15:55:37 2020 authpriv.info dropbear[1853]: Not backgrounding
Sat Oct 17 15:55:39 2020 kern.info kernel: [   55.047809] IPv6: ADDRCONF(NETDEV_UP): lo: link is not ready
Sat Oct 17 15:55:39 2020 kern.info kernel: [   55.191615] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Sat Oct 17 15:55:40 2020 kern.info kernel: [   55.473255] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
Sat Oct 17 15:55:40 2020 kern.info kernel: [   55.675611] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
Sat Oct 17 15:55:40 2020 kern.info kernel: [   55.705760] br-lan: port 1(eth1.1) entered blocking state
Sat Oct 17 15:55:40 2020 kern.info kernel: [   55.711345] br-lan: port 1(eth1.1) entered disabled state
Sat Oct 17 15:55:40 2020 kern.info kernel: [   55.717364] device eth1.1 entered promiscuous mode
Sat Oct 17 15:55:40 2020 kern.info kernel: [   55.722338] device eth1 entered promiscuous mode
Sat Oct 17 15:55:40 2020 daemon.notice netifd: Interface 'lan' is enabled
Sat Oct 17 15:55:40 2020 daemon.notice netifd: Interface 'lan' is setting up now
Sat Oct 17 15:55:40 2020 daemon.notice netifd: Interface 'lan' is now up
Sat Oct 17 15:55:40 2020 daemon.notice netifd: Interface 'loopback' is enabled
Sat Oct 17 15:55:40 2020 daemon.notice netifd: Interface 'loopback' is setting up now
Sat Oct 17 15:55:40 2020 daemon.notice netifd: Interface 'loopback' is now up
Sat Oct 17 15:55:40 2020 kern.info kernel: [   55.794362] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Sat Oct 17 15:55:40 2020 daemon.notice netifd: Interface 'wan' is enabled
Sat Oct 17 15:55:40 2020 daemon.notice netifd: Network device 'lo' link is up
Sat Oct 17 15:55:40 2020 daemon.notice netifd: Interface 'loopback' has link connectivity
Sat Oct 17 15:55:41 2020 kern.info kernel: [   57.316139] eth1: link up (1000Mbps/Full duplex)
Sat Oct 17 15:55:41 2020 kern.info kernel: [   57.320937] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
Sat Oct 17 15:55:41 2020 daemon.notice netifd: Network device 'eth1' link is up
Sat Oct 17 15:55:42 2020 kern.info kernel: [   57.414092] br-lan: port 1(eth1.1) entered blocking state
Sat Oct 17 15:55:42 2020 kern.info kernel: [   57.419731] br-lan: port 1(eth1.1) entered forwarding state
Sat Oct 17 15:55:42 2020 daemon.notice netifd: VLAN 'eth1.1' link is up
Sat Oct 17 15:55:42 2020 daemon.notice netifd: bridge 'br-lan' link is up
Sat Oct 17 15:55:42 2020 daemon.notice netifd: Interface 'lan' has link connectivity
Sat Oct 17 15:55:42 2020 kern.info kernel: [   57.878222] eth0: link up (100Mbps/Full duplex)
Sat Oct 17 15:55:42 2020 kern.info kernel: [   57.883106] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Sat Oct 17 15:55:42 2020 daemon.notice netifd: Network device 'eth0' link is up
Sat Oct 17 15:55:42 2020 daemon.notice netifd: Interface 'wan' has link connectivity
Sat Oct 17 15:55:42 2020 daemon.notice netifd: Interface 'wan' is setting up now
Sat Oct 17 15:55:43 2020 daemon.notice netifd: wan (2250): udhcpc: started, v1.28.3
Sat Oct 17 15:55:44 2020 daemon.notice netifd: wan (2250): udhcpc: sending discover
Sat Oct 17 15:55:44 2020 daemon.notice netifd: wan (2250): udhcpc: sending select for 192.168.1.10
Sat Oct 17 15:55:44 2020 daemon.notice netifd: wan (2250): udhcpc: lease of 192.168.1.10 obtained, lease time 2147483
Sat Oct 17 15:55:46 2020 daemon.notice netifd: Interface 'wan' is now up
Sat Oct 17 15:55:46 2020 daemon.info dnsmasq[1475]: reading /tmp/resolv.conf.auto
Sat Oct 17 15:55:46 2020 daemon.info dnsmasq[1475]: using local addresses only for domain test
Sat Oct 17 15:55:46 2020 daemon.info dnsmasq[1475]: using local addresses only for domain onion
Sat Oct 17 15:55:46 2020 daemon.info dnsmasq[1475]: using local addresses only for domain localhost
Sat Oct 17 15:55:46 2020 daemon.info dnsmasq[1475]: using local addresses only for domain invalid
Sat Oct 17 15:55:46 2020 daemon.info dnsmasq[1475]: using local addresses only for domain bind
Sat Oct 17 15:55:46 2020 daemon.info dnsmasq[1475]: using local addresses only for domain lan
Sat Oct 17 15:55:46 2020 daemon.info dnsmasq[1475]: using nameserver 192.168.1.1#53
Sat Oct 17 15:55:46 2020 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Sat Oct 17 15:55:48 2020 daemon.info dnsmasq[1475]: exiting on receipt of SIGTERM
Sat Oct 17 15:55:48 2020 user.notice ucitrack: Setting up /etc/config/network reload dependency on /etc/config/dhcp
Sat Oct 17 15:55:48 2020 daemon.info dnsmasq[2513]: started, version 2.80test2 cachesize 150
Sat Oct 17 15:55:48 2020 daemon.info dnsmasq[2513]: DNS service limited to local subnets
Sat Oct 17 15:55:48 2020 daemon.info dnsmasq[2513]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Sat Oct 17 15:55:48 2020 daemon.info dnsmasq-dhcp[2513]: DHCP, IP range 192.168.8.2 -- 192.168.8.249, lease time 12h
Sat Oct 17 15:55:48 2020 daemon.info dnsmasq[2513]: using local addresses only for domain test
Sat Oct 17 15:55:48 2020 daemon.info dnsmasq[2513]: using local addresses only for domain onion
Sat Oct 17 15:55:48 2020 daemon.info dnsmasq[2513]: using local addresses only for domain localhost
Sat Oct 17 15:55:48 2020 daemon.info dnsmasq[2513]: using local addresses only for domain invalid
Sat Oct 17 15:55:48 2020 daemon.info dnsmasq[2513]: using local addresses only for domain bind
Sat Oct 17 15:55:48 2020 daemon.info dnsmasq[2513]: using local addresses only for domain lan
Sat Oct 17 15:55:48 2020 daemon.info dnsmasq[2513]: reading /tmp/resolv.conf.auto
Sat Oct 17 15:55:48 2020 daemon.info dnsmasq[2513]: using nameserver 192.168.1.1#53
Sat Oct 17 15:55:48 2020 daemon.info dnsmasq[2513]: read /etc/hosts - 4 addresses
Sat Oct 17 15:55:48 2020 daemon.info dnsmasq[2513]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Sat Oct 17 15:55:48 2020 daemon.info dnsmasq-dhcp[2513]: read /etc/ethers - 0 addresses
Sat Oct 17 15:55:48 2020 daemon.info dnsmasq-dhcp[2513]: DHCPDISCOVER(br-lan) 64:95:6c:13:cb:6c
Sat Oct 17 15:55:48 2020 daemon.info dnsmasq-dhcp[2513]: DHCPOFFER(br-lan) 192.168.8.83 64:95:6c:13:cb:6c
Sat Oct 17 15:55:48 2020 user.notice ucitrack: Setting up /etc/config/network reload dependency on /etc/config/radvd
Sat Oct 17 15:55:48 2020 daemon.info dnsmasq-dhcp[2513]: DHCPREQUEST(br-lan) 192.168.8.83 64:95:6c:13:cb:6c
Sat Oct 17 15:55:48 2020 daemon.info dnsmasq-dhcp[2513]: DHCPACK(br-lan) 192.168.8.83 64:95:6c:13:cb:6c LGwebOSTV
Sat Oct 17 15:55:48 2020 user.notice ucitrack: Setting up /etc/config/wireless reload dependency on /etc/config/network
Sat Oct 17 15:55:49 2020 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Sat Oct 17 15:55:50 2020 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/luci-splash
Sat Oct 17 15:55:50 2020 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/qos
Sat Oct 17 15:55:50 2020 daemon.err hostapd: Configuration file: /var/run/hostapd-phy1.conf
Sat Oct 17 15:55:50 2020 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/miniupnpd
Sat Oct 17 15:55:50 2020 user.notice ucitrack: Setting up /etc/config/dhcp reload dependency on /etc/config/odhcpd
Sat Oct 17 15:55:51 2020 user.notice ucitrack: Setting up /etc/config/system reload trigger for non-procd /etc/init.d/led
Sat Oct 17 15:55:51 2020 user.notice ucitrack: Setting up /etc/config/system reload dependency on /etc/config/luci_statistics
Sat Oct 17 15:55:52 2020 user.notice ucitrack: Setting up /etc/config/system reload dependency on /etc/config/dhcp
Sat Oct 17 15:55:52 2020 user.notice ucitrack: Setting up /etc/config/mwan3 reload trigger for non-procd /etc/init.d/mwan3
Sat Oct 17 15:55:52 2020 daemon.info dnsmasq[2513]: exiting on receipt of SIGTERM
Sat Oct 17 15:55:53 2020 daemon.notice procd: /etc/rc.d/S90vpn-service: cat: can't open '/etc/openvpn/ovpn/server.ovpn': No such file or directory
Sat Oct 17 15:55:53 2020 daemon.info dnsmasq[2740]: started, version 2.80test2 cachesize 150
Sat Oct 17 15:55:53 2020 kern.info kernel: [   68.774196] br-lan: port 2(wlan0) entered blocking state
Sat Oct 17 15:55:53 2020 kern.info kernel: [   68.779886] br-lan: port 2(wlan0) entered disabled state
Sat Oct 17 15:55:53 2020 kern.info kernel: [   68.785781] device wlan0 entered promiscuous mode
Sat Oct 17 15:55:53 2020 daemon.info dnsmasq[2740]: DNS service limited to local subnets
Sat Oct 17 15:55:53 2020 daemon.info dnsmasq[2740]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Sat Oct 17 15:55:53 2020 daemon.info dnsmasq-dhcp[2740]: DHCP, IP range 192.168.8.2 -- 192.168.8.249, lease time 12h
Sat Oct 17 15:55:53 2020 daemon.info dnsmasq[2740]: using local addresses only for domain test
Sat Oct 17 15:55:53 2020 daemon.info dnsmasq[2740]: using local addresses only for domain onion
Sat Oct 17 15:55:53 2020 daemon.info dnsmasq[2740]: using local addresses only for domain localhost
Sat Oct 17 15:55:53 2020 daemon.info dnsmasq[2740]: using local addresses only for domain invalid
Sat Oct 17 15:55:53 2020 daemon.info dnsmasq[2740]: using local addresses only for domain bind
Sat Oct 17 15:55:53 2020 daemon.info dnsmasq[2740]: using local addresses only for domain lan
Sat Oct 17 15:55:53 2020 daemon.info dnsmasq[2740]: reading /tmp/resolv.conf.auto
Sat Oct 17 15:55:53 2020 daemon.info dnsmasq[2740]: using nameserver 192.168.1.1#53
Sat Oct 17 15:55:53 2020 daemon.info dnsmasq[2740]: read /etc/hosts - 4 addresses
Sat Oct 17 15:55:53 2020 daemon.info dnsmasq[2740]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Sat Oct 17 15:55:53 2020 daemon.info dnsmasq-dhcp[2740]: read /etc/ethers - 0 addresses
Sat Oct 17 15:55:53 2020 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->HT_SCAN
Sat Oct 17 15:55:53 2020 kern.info kernel: [   68.872149] br-lan: port 3(wlan1) entered blocking state
Sat Oct 17 15:55:53 2020 kern.info kernel: [   68.877711] br-lan: port 3(wlan1) entered disabled state
Sat Oct 17 15:55:53 2020 kern.info kernel: [   68.883585] device wlan1 entered promiscuous mode
Sat Oct 17 15:55:53 2020 daemon.notice hostapd: wlan1: interface state UNINITIALIZED->HT_SCAN
Sat Oct 17 15:55:53 2020 daemon.notice hostapd: handle_probe_req: send failed
Sat Oct 17 15:55:53 2020 daemon.err hostapd: Using interface wlan0 with hwaddr 94:83:c4:05:ff:af and ssid "Marco-Massimo Salotto 5G"
Sat Oct 17 15:55:54 2020 daemon.notice procd: /etc/rc.d/S95done: killall: uqmi: no process killed
Sat Oct 17 15:55:54 2020 daemon.err hostapd: Using interface wlan1 with hwaddr 94:83:c4:05:ff:ae and ssid "Massimo-Marco Salotto 2.4Ghz"
Sat Oct 17 15:55:55 2020 kern.info kernel: [   71.027384] br-lan: port 2(wlan0) entered blocking state
Sat Oct 17 15:55:55 2020 kern.info kernel: [   71.032885] br-lan: port 2(wlan0) entered forwarding state
Sat Oct 17 15:55:55 2020 daemon.notice hostapd: wlan0: interface state HT_SCAN->ENABLED
Sat Oct 17 15:55:55 2020 daemon.notice hostapd: wlan0: AP-ENABLED
Sat Oct 17 15:55:56 2020 daemon.notice netifd: Network device 'wlan0' link is up
Sat Oct 17 15:55:56 2020 daemon.notice netifd: Interface 'lan' is now down
Sat Oct 17 15:55:56 2020 kern.info kernel: [   72.026615] br-lan: port 2(wlan0) entered disabled state
Sat Oct 17 15:55:56 2020 kern.info kernel: [   72.032188] br-lan: port 1(eth1.1) entered disabled state
Sat Oct 17 15:55:56 2020 kern.info kernel: [   72.082329] device eth1.1 left promiscuous mode
Sat Oct 17 15:55:56 2020 kern.info kernel: [   72.087096] device eth1 left promiscuous mode
Sat Oct 17 15:55:56 2020 kern.info kernel: [   72.091994] br-lan: port 1(eth1.1) entered disabled state
Sat Oct 17 15:55:56 2020 kern.info kernel: [   72.164037] eth1: link down
Sat Oct 17 15:55:56 2020 kern.info kernel: [   72.203256] device wlan0 left promiscuous mode
Sat Oct 17 15:55:56 2020 kern.info kernel: [   72.208022] br-lan: port 2(wlan0) entered disabled state
Sat Oct 17 15:55:56 2020 kern.info kernel: [   72.279980] device wlan1 left promiscuous mode
Sat Oct 17 15:55:56 2020 kern.info kernel: [   72.284747] br-lan: port 3(wlan1) entered disabled state
Sat Oct 17 15:55:56 2020 daemon.notice netifd: Interface 'lan' is disabled
Sat Oct 17 15:55:56 2020 daemon.notice netifd: VLAN 'eth1.1' link is down
Sat Oct 17 15:55:56 2020 daemon.notice netifd: bridge 'br-lan' link is down
Sat Oct 17 15:55:56 2020 daemon.notice netifd: Interface 'lan' has link connectivity loss
Sat Oct 17 15:55:56 2020 daemon.notice netifd: Network device 'eth1' link is down
Sat Oct 17 15:55:57 2020 daemon.notice netifd: Interface 'loopback' is now down
Sat Oct 17 15:55:57 2020 daemon.notice netifd: Interface 'loopback' is disabled
Sat Oct 17 15:55:57 2020 daemon.notice netifd: Network device 'lo' link is down
Sat Oct 17 15:55:57 2020 daemon.notice netifd: Interface 'loopback' has link connectivity loss
Sat Oct 17 15:55:57 2020 daemon.notice hostapd: wlan1: interface state HT_SCAN->ENABLED
Sat Oct 17 15:55:57 2020 daemon.notice hostapd: wlan1: AP-ENABLED
Sat Oct 17 15:55:57 2020 daemon.notice netifd: wan (2250): udhcpc: received SIGTERM
Sat Oct 17 15:55:57 2020 daemon.notice netifd: Interface 'wan' is now down
Sat Oct 17 15:55:57 2020 kern.info kernel: [   72.967977] eth0: link down
Sat Oct 17 15:55:57 2020 daemon.notice hostapd: wlan0: interface state ENABLED->DISABLED
Sat Oct 17 15:55:57 2020 daemon.notice hostapd: wlan0: AP-DISABLED
Sat Oct 17 15:55:57 2020 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Sat Oct 17 15:55:57 2020 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Sat Oct 17 15:55:57 2020 daemon.notice netifd: Interface 'wan' is disabled
Sat Oct 17 15:55:57 2020 daemon.warn dnsmasq[2740]: no servers found in /tmp/resolv.conf.auto, will retry
Sat Oct 17 15:55:57 2020 daemon.notice netifd: Network device 'eth0' link is down
Sat Oct 17 15:55:57 2020 daemon.notice netifd: Interface 'wan' has link connectivity loss
Sat Oct 17 15:55:58 2020 daemon.notice hostapd: nl80211: Failed to remove interface wlan0 from bridge br-lan: No such device
Sat Oct 17 15:55:58 2020 daemon.info hostapd: wlan1: STA 44:23:7c:44:d2:a0 IEEE 802.11: authenticated
Sat Oct 17 15:55:58 2020 daemon.info hostapd: wlan1: STA 44:23:7c:44:d2:a0 IEEE 802.11: associated (aid 1)
Sat Oct 17 15:55:58 2020 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 44:23:7c:44:d2:a0
Sat Oct 17 15:55:58 2020 daemon.info hostapd: wlan1: STA 44:23:7c:44:d2:a0 RADIUS: starting accounting session 5BB1C2B47E684264
Sat Oct 17 15:55:58 2020 daemon.info hostapd: wlan1: STA 44:23:7c:44:d2:a0 WPA: pairwise key handshake completed (RSN)
Sat Oct 17 15:55:59 2020 user.notice : Added device handler type: tunnel
Sat Oct 17 15:55:59 2020 user.notice : Added device handler type: Network device
Sat Oct 17 15:55:59 2020 user.notice : Added device handler type: bridge
Sat Oct 17 15:55:59 2020 user.notice : Added device handler type: veth
Sat Oct 17 15:55:59 2020 user.notice : Added device handler type: macvlan
Sat Oct 17 15:55:59 2020 user.notice : Added device handler type: 8021ad
Sat Oct 17 15:55:59 2020 user.notice : Added device handler type: 8021q
Sat Oct 17 15:55:59 2020 kern.notice kernel: [   74.740768] random: crng init done
Sat Oct 17 15:55:59 2020 kern.notice kernel: [   74.744300] random: 6 urandom warning(s) missed due to ratelimiting
Sat Oct 17 15:55:59 2020 daemon.notice procd: /etc/rc.d/S96led: setting up led WLAN2G
Sat Oct 17 15:55:59 2020 daemon.notice procd: /etc/rc.d/S96led: setting up led WLAN5G
Sat Oct 17 15:56:01 2020 daemon.info hostapd: wlan1: STA 50:ec:50:ee:04:07 IEEE 802.11: authenticated
Sat Oct 17 15:56:01 2020 daemon.info hostapd: wlan1: STA 50:ec:50:ee:04:07 IEEE 802.11: associated (aid 2)
Sat Oct 17 15:56:01 2020 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 50:ec:50:ee:04:07
Sat Oct 17 15:56:01 2020 daemon.info hostapd: wlan1: STA 50:ec:50:ee:04:07 RADIUS: starting accounting session E862C060D6AC8771
Sat Oct 17 15:56:01 2020 daemon.info hostapd: wlan1: STA 50:ec:50:ee:04:07 WPA: pairwise key handshake completed (RSN)
Sat Oct 17 15:56:01 2020 daemon.notice hostapd: wlan1: interface state ENABLED->DISABLED
Sat Oct 17 15:56:01 2020 daemon.notice hostapd: wlan1: AP-STA-DISCONNECTED 50:ec:50:ee:04:07
Sat Oct 17 15:56:01 2020 daemon.notice hostapd: wlan1: AP-STA-DISCONNECTED 44:23:7c:44:d2:a0
Sat Oct 17 15:56:01 2020 daemon.notice hostapd: wlan1: AP-DISABLED
Sat Oct 17 15:56:01 2020 daemon.notice hostapd: wlan1: CTRL-EVENT-TERMINATING
Sat Oct 17 15:56:01 2020 daemon.notice hostapd: nl80211: deinit ifname=wlan1 disabled_11b_rates=0
Sat Oct 17 15:56:01 2020 daemon.notice hostapd: nl80211: Failed to remove interface wlan1 from bridge br-lan: No such device
Sat Oct 17 15:56:02 2020 kern.info kernel: [   78.226004] IPv6: ADDRCONF(NETDEV_UP): lo: link is not ready
Sat Oct 17 15:56:03 2020 kern.info kernel: [   78.369807] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Sat Oct 17 15:56:03 2020 kern.info kernel: [   78.651719] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
Sat Oct 17 15:56:03 2020 kern.info kernel: [   78.845505] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
Sat Oct 17 15:56:03 2020 kern.info kernel: [   78.870613] br-lan: port 1(eth1.1) entered blocking state
Sat Oct 17 15:56:03 2020 kern.info kernel: [   78.876258] br-lan: port 1(eth1.1) entered disabled state
Sat Oct 17 15:56:03 2020 kern.info kernel: [   78.882227] device eth1.1 entered promiscuous mode
Sat Oct 17 15:56:03 2020 kern.info kernel: [   78.887223] device eth1 entered promiscuous mode
Sat Oct 17 15:56:03 2020 daemon.notice netifd: Interface 'lan' is enabled
Sat Oct 17 15:56:03 2020 daemon.notice netifd: Interface 'lan' is setting up now
Sat Oct 17 15:56:03 2020 daemon.notice netifd: Interface 'lan' is now up
Sat Oct 17 15:56:03 2020 daemon.notice netifd: Interface 'loopback' is enabled
Sat Oct 17 15:56:03 2020 daemon.notice netifd: Interface 'loopback' is setting up now
Sat Oct 17 15:56:03 2020 daemon.notice netifd: Interface 'loopback' is now up
Sat Oct 17 15:56:03 2020 kern.info kernel: [   78.969886] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Sat Oct 17 15:56:03 2020 daemon.notice netifd: Interface 'wan' is enabled
Sat Oct 17 15:56:03 2020 daemon.notice netifd: Network device 'lo' link is up
Sat Oct 17 15:56:03 2020 daemon.notice netifd: Interface 'loopback' has link connectivity
Sat Oct 17 15:56:05 2020 kern.info kernel: [   80.486147] eth1: link up (1000Mbps/Full duplex)
Sat Oct 17 15:56:05 2020 kern.info kernel: [   80.490953] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
Sat Oct 17 15:56:05 2020 daemon.notice netifd: Network device 'eth1' link is up
Sat Oct 17 15:56:05 2020 daemon.notice netifd: VLAN 'eth1.1' link is up
Sat Oct 17 15:56:05 2020 kern.info kernel: [   80.582017] br-lan: port 1(eth1.1) entered blocking state
Sat Oct 17 15:56:05 2020 kern.info kernel: [   80.587666] br-lan: port 1(eth1.1) entered forwarding state
Sat Oct 17 15:56:05 2020 daemon.notice netifd: bridge 'br-lan' link is up
Sat Oct 17 15:56:05 2020 daemon.notice netifd: Interface 'lan' has link connectivity
Sat Oct 17 15:56:05 2020 daemon.info dnsmasq-dhcp[2740]: DHCPREQUEST(br-lan) 192.168.8.83 64:95:6c:13:cb:6c
Sat Oct 17 15:56:05 2020 daemon.info dnsmasq-dhcp[2740]: DHCPACK(br-lan) 192.168.8.83 64:95:6c:13:cb:6c LGwebOSTV
Sat Oct 17 15:56:05 2020 kern.info kernel: [   81.078229] eth0: link up (100Mbps/Full duplex)
Sat Oct 17 15:56:05 2020 kern.info kernel: [   81.082981] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Sat Oct 17 15:56:05 2020 daemon.notice netifd: Network device 'eth0' link is up
Sat Oct 17 15:56:05 2020 daemon.notice netifd: Interface 'wan' has link connectivity
Sat Oct 17 15:56:05 2020 daemon.notice netifd: Interface 'wan' is setting up now
Sat Oct 17 15:56:07 2020 daemon.notice netifd: wan (3550): udhcpc: started, v1.28.3
Sat Oct 17 15:56:07 2020 daemon.info dnsmasq[2740]: exiting on receipt of SIGTERM
Sat Oct 17 15:56:07 2020 daemon.info dnsmasq[3566]: started, version 2.80test2 cachesize 150
Sat Oct 17 15:56:07 2020 daemon.info dnsmasq[3566]: DNS service limited to local subnets
Sat Oct 17 15:56:07 2020 daemon.info dnsmasq[3566]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Sat Oct 17 15:56:07 2020 daemon.info dnsmasq-dhcp[3566]: DHCP, IP range 192.168.8.2 -- 192.168.8.249, lease time 12h
Sat Oct 17 15:56:07 2020 daemon.info dnsmasq[3566]: using local addresses only for domain test
Sat Oct 17 15:56:07 2020 daemon.info dnsmasq[3566]: using local addresses only for domain onion
Sat Oct 17 15:56:07 2020 daemon.info dnsmasq[3566]: using local addresses only for domain localhost
Sat Oct 17 15:56:07 2020 daemon.info dnsmasq[3566]: using local addresses only for domain invalid
Sat Oct 17 15:56:07 2020 daemon.info dnsmasq[3566]: using local addresses only for domain bind
Sat Oct 17 15:56:07 2020 daemon.info dnsmasq[3566]: using local addresses only for domain lan
Sat Oct 17 15:56:07 2020 daemon.warn dnsmasq[3566]: no servers found in /tmp/resolv.conf.auto, will retry
Sat Oct 17 15:56:07 2020 daemon.info dnsmasq[3566]: read /etc/hosts - 4 addresses
Sat Oct 17 15:56:07 2020 daemon.info dnsmasq[3566]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Sat Oct 17 15:56:07 2020 daemon.info dnsmasq-dhcp[3566]: read /etc/ethers - 0 addresses
Sat Oct 17 15:56:07 2020 daemon.notice netifd: wan (3550): udhcpc: sending discover
Sat Oct 17 15:56:07 2020 daemon.notice netifd: wan (3550): udhcpc: sending select for 192.168.1.10
Sat Oct 17 15:56:07 2020 daemon.notice netifd: wan (3550): udhcpc: lease of 192.168.1.10 obtained, lease time 2147483
Sat Oct 17 15:56:08 2020 daemon.err hostapd: Configuration file: /var/run/hostapd-phy1.conf
Sat Oct 17 15:56:08 2020 kern.info kernel: [   83.869908] br-lan: port 2(wlan1) entered blocking state
Sat Oct 17 15:56:08 2020 kern.info kernel: [   83.875468] br-lan: port 2(wlan1) entered disabled state
Sat Oct 17 15:56:08 2020 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Sat Oct 17 15:56:08 2020 daemon.notice procd: /etc/rc.d/S99gl_route_policy: uci: Entry not found
Sat Oct 17 15:56:08 2020 kern.info kernel: [   84.035491] device wlan1 entered promiscuous mode
Sat Oct 17 15:56:08 2020 user.info : Sta config not set!!!!
Sat Oct 17 15:56:11 2020 daemon.notice procd: /etc/rc.d/S99lighttpd: netstat: showing only processes with your user ID
Sat Oct 17 15:56:12 2020 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Sat Oct 17 15:56:13 2020 daemon.notice hostapd: wlan1: interface state UNINITIALIZED->HT_SCAN
Sat Oct 17 15:56:13 2020 daemon.info dnsmasq-dhcp[3566]: DHCPDISCOVER(br-lan) 8c:45:00:f7:66:ae
Sat Oct 17 15:56:13 2020 daemon.info dnsmasq-dhcp[3566]: DHCPOFFER(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Sat Oct 17 15:56:13 2020 kern.info kernel: [   88.482295] br-lan: port 3(wlan0) entered blocking state
Sat Oct 17 15:56:13 2020 kern.info kernel: [   88.487867] br-lan: port 3(wlan0) entered disabled state
Sat Oct 17 15:56:13 2020 daemon.notice netifd: Interface 'wan' is now up
Sat Oct 17 15:56:13 2020 kern.info kernel: [   88.675188] device wlan0 entered promiscuous mode
Sat Oct 17 15:56:13 2020 kern.info kernel: [   88.680194] br-lan: port 3(wlan0) entered blocking state
Sat Oct 17 15:56:13 2020 kern.info kernel: [   88.685738] br-lan: port 3(wlan0) entered forwarding state
Sat Oct 17 15:56:13 2020 kern.info kernel: [   88.696201] br-lan: port 3(wlan0) entered disabled state
Sat Oct 17 15:56:13 2020 daemon.info dnsmasq-dhcp[3566]: DHCPREQUEST(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Sat Oct 17 15:56:13 2020 daemon.info dnsmasq-dhcp[3566]: DHCPACK(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Sat Oct 17 15:56:13 2020 daemon.warn dnsmasq-dhcp[3566]: Error sending DHCP packet to 192.168.8.66: Operation not permitted
Sat Oct 17 15:56:13 2020 daemon.info dnsmasq[3566]: reading /tmp/resolv.conf.auto
Sat Oct 17 15:56:13 2020 daemon.info dnsmasq[3566]: using local addresses only for domain test
Sat Oct 17 15:56:13 2020 daemon.info dnsmasq[3566]: using local addresses only for domain onion
Sat Oct 17 15:56:13 2020 daemon.info dnsmasq[3566]: using local addresses only for domain localhost
Sat Oct 17 15:56:13 2020 daemon.info dnsmasq[3566]: using local addresses only for domain invalid
Sat Oct 17 15:56:13 2020 daemon.info dnsmasq[3566]: using local addresses only for domain bind
Sat Oct 17 15:56:13 2020 daemon.info dnsmasq[3566]: using local addresses only for domain lan
Sat Oct 17 15:56:13 2020 daemon.info dnsmasq[3566]: using nameserver 192.168.1.1#53
Sat Oct 17 15:56:13 2020 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->HT_SCAN
Sat Oct 17 15:56:13 2020 daemon.notice hostapd: handle_probe_req: send failed
Sat Oct 17 15:56:13 2020 daemon.err hostapd: Using interface wlan0 with hwaddr 94:83:c4:05:ff:af and ssid "Marco-Massimo Salotto 5G"
Sat Oct 17 15:56:14 2020 daemon.notice hostapd: handle_probe_req: send failed
Sat Oct 17 15:56:14 2020 daemon.err hostapd: Using interface wlan1 with hwaddr 94:83:c4:05:ff:ae and ssid "Massimo-Marco Salotto 2.4Ghz"
Sat Oct 17 15:56:16 2020 daemon.info dnsmasq-dhcp[3566]: DHCPREQUEST(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Sat Oct 17 15:56:16 2020 daemon.info dnsmasq-dhcp[3566]: DHCPACK(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Sat Oct 17 15:56:55 2020 kern.info kernel: [   92.428801] br-lan: port 3(wlan0) entered blocking state
Sat Oct 17 15:56:55 2020 kern.info kernel: [   92.434299] br-lan: port 3(wlan0) entered forwarding state
Sat Oct 17 15:56:55 2020 daemon.notice hostapd: wlan0: interface state HT_SCAN->ENABLED
Sat Oct 17 15:56:55 2020 daemon.notice hostapd: wlan0: AP-ENABLED
Sat Oct 17 15:56:56 2020 daemon.notice netifd: Network device 'wlan0' link is up
Sat Oct 17 15:56:56 2020 daemon.notice hostapd: wlan1: interface state HT_SCAN->ENABLED
Sat Oct 17 15:56:56 2020 daemon.notice hostapd: wlan1: AP-ENABLED
Sat Oct 17 15:56:57 2020 kern.info kernel: [   93.884013] br-lan: port 2(wlan1) entered blocking state
Sat Oct 17 15:56:57 2020 kern.info kernel: [   93.889554] br-lan: port 2(wlan1) entered forwarding state
Sat Oct 17 15:56:57 2020 daemon.notice netifd: Network device 'wlan1' link is up
Sat Oct 17 15:56:59 2020 daemon.info dnsmasq[3566]: exiting on receipt of SIGTERM
Sat Oct 17 15:56:59 2020 daemon.info dnsmasq[4477]: started, version 2.80test2 cachesize 150
Sat Oct 17 15:56:59 2020 daemon.info dnsmasq[4477]: DNS service limited to local subnets
Sat Oct 17 15:56:59 2020 daemon.info dnsmasq[4477]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Sat Oct 17 15:56:59 2020 daemon.info dnsmasq-dhcp[4477]: DHCP, IP range 192.168.8.2 -- 192.168.8.249, lease time 12h
Sat Oct 17 15:56:59 2020 daemon.info dnsmasq[4477]: using local addresses only for domain test
Sat Oct 17 15:56:59 2020 daemon.info dnsmasq[4477]: using local addresses only for domain onion
Sat Oct 17 15:56:59 2020 daemon.info dnsmasq[4477]: using local addresses only for domain localhost
Sat Oct 17 15:56:59 2020 daemon.info dnsmasq[4477]: using local addresses only for domain invalid
Sat Oct 17 15:56:59 2020 daemon.info dnsmasq[4477]: using local addresses only for domain bind
Sat Oct 17 15:56:59 2020 daemon.info dnsmasq[4477]: using local addresses only for domain lan
Sat Oct 17 15:56:59 2020 daemon.info dnsmasq[4477]: reading /tmp/resolv.conf.auto
Sat Oct 17 15:56:59 2020 daemon.info dnsmasq[4477]: using nameserver 192.168.1.1#53
Sat Oct 17 15:56:59 2020 daemon.info dnsmasq[4477]: read /etc/hosts - 4 addresses
Sat Oct 17 15:56:59 2020 daemon.info dnsmasq[4477]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Sat Oct 17 15:56:59 2020 daemon.info dnsmasq-dhcp[4477]: read /etc/ethers - 0 addresses
Sat Oct 17 15:57:00 2020 daemon.info hostapd: wlan1: STA 50:ec:50:ee:04:07 IEEE 802.11: authenticated
Sat Oct 17 15:57:00 2020 daemon.info hostapd: wlan1: STA 50:ec:50:ee:04:07 IEEE 802.11: associated (aid 1)
Sat Oct 17 15:57:01 2020 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 50:ec:50:ee:04:07
Sat Oct 17 15:57:01 2020 daemon.info hostapd: wlan1: STA 50:ec:50:ee:04:07 RADIUS: starting accounting session 8F62E29D293FB956
Sat Oct 17 15:57:01 2020 daemon.info hostapd: wlan1: STA 50:ec:50:ee:04:07 WPA: pairwise key handshake completed (RSN)
Sat Oct 17 15:57:05 2020 daemon.info procd: - init complete -
Sat Oct 17 15:57:06 2020 daemon.info hostapd: wlan1: STA a4:50:46:14:0e:f5 IEEE 802.11: authenticated
Sat Oct 17 15:57:06 2020 daemon.info hostapd: wlan1: STA a4:50:46:14:0e:f5 IEEE 802.11: associated (aid 2)
Sat Oct 17 15:57:06 2020 daemon.notice hostapd: wlan1: AP-STA-CONNECTED a4:50:46:14:0e:f5
Sat Oct 17 15:57:06 2020 daemon.info hostapd: wlan1: STA a4:50:46:14:0e:f5 RADIUS: starting accounting session 49C9BDFB5CDBD108
Sat Oct 17 15:57:06 2020 daemon.info hostapd: wlan1: STA a4:50:46:14:0e:f5 WPA: pairwise key handshake completed (RSN)
Sat Oct 17 15:57:06 2020 daemon.info dnsmasq-dhcp[4477]: DHCPDISCOVER(br-lan) a4:50:46:14:0e:f5
Sat Oct 17 15:57:06 2020 daemon.info dnsmasq-dhcp[4477]: DHCPOFFER(br-lan) 192.168.8.157 a4:50:46:14:0e:f5
Sat Oct 17 15:57:06 2020 daemon.info dnsmasq-dhcp[4477]: DHCPREQUEST(br-lan) 192.168.8.157 a4:50:46:14:0e:f5
Sat Oct 17 15:57:06 2020 daemon.info dnsmasq-dhcp[4477]: DHCPACK(br-lan) 192.168.8.157 a4:50:46:14:0e:f5
Sat Oct 17 15:57:08 2020 user.notice firewall: Reloading firewall due to ifup of wan (eth0)
Sat Oct 17 15:57:10 2020 daemon.info dnsmasq-dhcp[4477]: DHCPDISCOVER(br-lan) f0:ef:86:2b:59:75
Sat Oct 17 15:57:10 2020 daemon.info dnsmasq-dhcp[4477]: DHCPOFFER(br-lan) 192.168.8.102 f0:ef:86:2b:59:75
Sat Oct 17 15:57:10 2020 daemon.info dnsmasq-dhcp[4477]: DHCPREQUEST(br-lan) 192.168.8.102 f0:ef:86:2b:59:75
Sat Oct 17 15:57:10 2020 daemon.info dnsmasq-dhcp[4477]: DHCPACK(br-lan) 192.168.8.102 f0:ef:86:2b:59:75 Chromecast
Sat Oct 17 15:57:12 2020 daemon.info dnsmasq-dhcp[4477]: DHCPDISCOVER(br-lan) 50:ec:50:ee:04:07
Sat Oct 17 15:57:12 2020 daemon.info dnsmasq-dhcp[4477]: DHCPOFFER(br-lan) 192.168.8.207 50:ec:50:ee:04:07
Sat Oct 17 15:57:12 2020 daemon.info dnsmasq-dhcp[4477]: DHCPREQUEST(br-lan) 192.168.8.207 50:ec:50:ee:04:07
Sat Oct 17 15:57:12 2020 daemon.info dnsmasq-dhcp[4477]: DHCPACK(br-lan) 192.168.8.207 50:ec:50:ee:04:07
Sat Oct 17 15:57:16 2020 daemon.info hostapd: wlan1: STA 44:23:7c:44:d2:a0 IEEE 802.11: authenticated
Sat Oct 17 15:57:16 2020 daemon.info hostapd: wlan1: STA 44:23:7c:44:d2:a0 IEEE 802.11: associated (aid 3)
Sat Oct 17 15:57:17 2020 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 44:23:7c:44:d2:a0
Sat Oct 17 15:57:17 2020 daemon.info hostapd: wlan1: STA 44:23:7c:44:d2:a0 RADIUS: starting accounting session F7A9DD973B01A3C6
Sat Oct 17 15:57:17 2020 daemon.info hostapd: wlan1: STA 44:23:7c:44:d2:a0 WPA: pairwise key handshake completed (RSN)
Sat Oct 17 15:57:20 2020 daemon.info dnsmasq-dhcp[4477]: DHCPDISCOVER(br-lan) 8c:45:00:f7:66:ae
Sat Oct 17 15:57:20 2020 daemon.info dnsmasq-dhcp[4477]: DHCPOFFER(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Sat Oct 17 15:57:20 2020 daemon.info dnsmasq-dhcp[4477]: DHCPREQUEST(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Sat Oct 17 15:57:20 2020 daemon.info dnsmasq-dhcp[4477]: DHCPACK(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Sat Oct 17 15:57:27 2020 daemon.info hostapd: wlan0: STA 8c:88:2b:00:04:24 IEEE 802.11: authenticated
Sat Oct 17 15:57:27 2020 daemon.info hostapd: wlan0: STA 8c:88:2b:00:04:24 IEEE 802.11: associated (aid 1)
Sat Oct 17 15:57:27 2020 daemon.notice hostapd: wlan0: AP-STA-CONNECTED 8c:88:2b:00:04:24
Sat Oct 17 15:57:27 2020 daemon.info hostapd: wlan0: STA 8c:88:2b:00:04:24 RADIUS: starting accounting session E68D87438D8128D2
Sat Oct 17 15:57:27 2020 daemon.info hostapd: wlan0: STA 8c:88:2b:00:04:24 WPA: pairwise key handshake completed (RSN)
Sat Oct 17 15:57:27 2020 daemon.info dnsmasq-dhcp[4477]: DHCPREQUEST(br-lan) 192.168.8.100 8c:88:2b:00:04:24
Sat Oct 17 15:57:27 2020 daemon.info dnsmasq-dhcp[4477]: DHCPACK(br-lan) 192.168.8.100 8c:88:2b:00:04:24 MASSIMO-PC
Sat Oct 17 15:57:45 2020 daemon.info dnsmasq-dhcp[4477]: DHCPDISCOVER(br-lan) 8c:45:00:f7:66:ae
Sat Oct 17 15:57:45 2020 daemon.info dnsmasq-dhcp[4477]: DHCPOFFER(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Sat Oct 17 15:57:45 2020 daemon.info dnsmasq-dhcp[4477]: DHCPREQUEST(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Sat Oct 17 15:57:45 2020 daemon.info dnsmasq-dhcp[4477]: DHCPACK(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Sat Oct 17 15:58:10 2020 daemon.info dnsmasq-dhcp[4477]: DHCPDISCOVER(br-lan) 8c:45:00:f7:66:ae
Sat Oct 17 15:58:10 2020 daemon.info dnsmasq-dhcp[4477]: DHCPOFFER(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Sat Oct 17 15:58:10 2020 daemon.info dnsmasq-dhcp[4477]: DHCPREQUEST(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Sat Oct 17 15:58:10 2020 daemon.info dnsmasq-dhcp[4477]: DHCPACK(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Sat Oct 17 15:58:34 2020 daemon.info dnsmasq-dhcp[4477]: DHCPDISCOVER(br-lan) 8c:45:00:f7:66:ae
Sat Oct 17 15:58:34 2020 daemon.info dnsmasq-dhcp[4477]: DHCPOFFER(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Sat Oct 17 15:58:34 2020 daemon.info dnsmasq-dhcp[4477]: DHCPREQUEST(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Sat Oct 17 15:58:34 2020 daemon.info dnsmasq-dhcp[4477]: DHCPACK(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Sat Oct 17 15:58:58 2020 daemon.info dnsmasq-dhcp[4477]: DHCPDISCOVER(br-lan) 8c:45:00:f7:66:ae
Sat Oct 17 15:58:58 2020 daemon.info dnsmasq-dhcp[4477]: DHCPOFFER(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Sat Oct 17 15:58:58 2020 daemon.info dnsmasq-dhcp[4477]: DHCPREQUEST(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Sat Oct 17 15:58:58 2020 daemon.info dnsmasq-dhcp[4477]: DHCPACK(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Sat Oct 17 15:59:23 2020 daemon.info dnsmasq-dhcp[4477]: DHCPDISCOVER(br-lan) 8c:45:00:f7:66:ae
Sat Oct 17 15:59:23 2020 daemon.info dnsmasq-dhcp[4477]: DHCPOFFER(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Sat Oct 17 15:59:23 2020 daemon.info dnsmasq-dhcp[4477]: DHCPREQUEST(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Sat Oct 17 15:59:23 2020 daemon.info dnsmasq-dhcp[4477]: DHCPACK(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Sat Oct 17 15:59:47 2020 daemon.info dnsmasq-dhcp[4477]: DHCPDISCOVER(br-lan) 8c:45:00:f7:66:ae
Sat Oct 17 15:59:47 2020 daemon.info dnsmasq-dhcp[4477]: DHCPOFFER(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Sat Oct 17 15:59:47 2020 daemon.info dnsmasq-dhcp[4477]: DHCPREQUEST(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Sat Oct 17 15:59:47 2020 daemon.info dnsmasq-dhcp[4477]: DHCPACK(br-lan) 192.168.8.66 8c:45:00:f7:66:ae
Well, I’ve just found the solution: disabling “DNS over TLS” make my boot time normal and every device reconnect correctly everytime and fast. “DNS over TLS” doesn’t work well upon reboot if I am using a static IP, but works everytime if I am using DHCP.
Strange that my most affected devices were 2 smart bulbs.
Also, if I enable “DNS over TLS” AND the side swith function (Wireguard ON/OFF) at the same time, the router doesn’t even reboot most of times and freeze with the only the power led on. Some other times it reboots very slowly but Wireguard can’t connect and there is no internet. If I move the switch it can reboot. I have this second problem using both 3.105 and 3.027, in fact I opened a topic about this some days ago: Link
Just tested ar750-3.105-1019, the problem is fixed. Every device works everytime upon reboot.
However, using DNS over TLS with wireguard switch function continue to freeze the router on boot.
