I changed all MAC addresses in Luci under “Interfaces” then I click “Advanced” tab I think? I do not have it here at this moment but if this is not clear I will log on and check.
For MT300A, if you change Mac address it may break the wifi when you have multiple wifi interfaces, including ap and sta. So you’d better clone using our UI which will deal with this.
For all the vap (ap and sta) interfaces, the Mac addresses should only be different in the last 8 bit.
For example, for the following Mac, only x:xx can be different for all the Mac addresses. Other digitals should be the same.
‘12:34:56:78:9x:xx’
@alzhao I do not understand nothings you are saying.
If you use repeater, they already have multiple wifi interfaces.
What is “use repeater” meaning? I have GL has only 2.4 radio. So is correct I do not have “multiple wifi interfaces” or is something else I do not understand? Please explain what you are saying to me.
Please I ask question “What you mean “when you have multiple wifi interfaces”? Can you provide example? I do not understand this sentence.” Now can you please explain? Please provide examples because nothings you saying is somethings I can understand.
