Is there a model for a 3D case for the Flint 2 GL-MT6000?
I need to put this router into another case and need a platform and place to mount the antennas.
We are unable to provide own detailed 3D structural design image.
You can measure the size of the motherboard + heatsink, design the 3D case according to the approximate size, and fill it with foam between the case and the motherboard to prevent vibration.
