We developed a custom board using the Domino Core module and we are trying to use all 3 Ethernet ports that are available. The 4 pins on the bottom of the module are actually working correctly as well as one of the ports on the side (I believe Port P4 is the one that is not showing up).
Does the firmware need to be recompiled for this additional port? its strange to me that the port tied to the bottom 4 pins works fine but the port on the side doesnt seem to show up. I tried “ifconfig eth2 up” through eth5 and I dont get anything.
Thank you for the quick response! That makes sense, I was able to get all 3 devices talking to the router. I had an issue with noise on the center tap.
