4.2.1 on AX1800: wrong labels for switch
when using the luci web interface to add VLANs to the switch ports, the interfaces have wrong labels, and an error message
Switch switch0 has an unknown topology - the VLAN settings might not be accurate.
is shown. E.g. a cable plugged into LAN4 port appears as CPU(eth0)
Instead of
Port1 Port2 Port3 Port4 Port5 CPU
it should probably be
CPU WAN LAN1 LAN2 LAN3 LAN4
What firmware version do you using?
Perhaps because the AX1800 does not use the standard DSA framework switch driver, its status on luci does not show correctly.
4.2.1 downloaded and installed manually, since the 4.1.? I had before did not offer automatic update.
