Noticed that almost all devices from 1300 series I do have (4x MT1300 and 1xB1300) already have firmware 4.3.7 listed as stable from download sirte. Are there plans for S1300 (one device only: unfortunatelly: used as main concentrator…)?
For a moment there were beta version for this model, but (at least for now) is gone from download site.
Have tried it (betwa version on S1300) but seems internal switch or external WAN were limited to 500MB/s only. Got back again to 3.X version
It looks like 4.3.7 beta 4 available on site as beta is not loading. Have tried in recovery mode, through UI (from 3.216, 3.215 and 3.105). Through UI tar file used in local upgrade keeps spinning forever and eventually stuck… Maybe some build issue?
Yes: uboot = recovery mode.
A bit progress, but still failed: used LUCI → loaded img file + erase all settings → update fail → but then in GL UI can use img file (without first step was stating that file is corrupted) → FW progressing, but after reboot still old FW (3.216)
Thanks. Seems there were some download issues. Had 4.3.7.b4 but build number were different. On another side. Now issue is with good cloud. Service is not starting at all. Is this this particular version/build issue?
root@GL-S1300:/etc/config# gl-cloud
: not found-cloud: line 1: uaS⚌
/usr/bin/gl-cloud: line 2: : not found
/usr/bin/gl-cloud: line 3: syntax error: unexpected word (expecting “)”)
root@GL-S1300:~# logread | grep gl-clou
Tue Dec 12 11:32:31 2023 daemon.info procd: Instance gl-cloud::instance1 s in a crash loop 6 crashes, 0 seconds since last crash
Tue Dec 12 11:36:10 2023 daemon.info procd: Instance gl-cloud::instance1 s in a crash loop 7 crashes, 0 seconds since last crash
Tue Dec 12 11:36:49 2023 daemon.info procd: Instance gl-cloud::instance1 s in a crash loop 6 crashes, 0 seconds since last crash
