could someone please, with no problem related to the WiFi, post a decent configuration?
I'm using 4.6.3-op24 firmware.
I'm especially interested in:
- country code setting
- these settings for 5Ghz
- these for 2.4Ghz
Thank you!
Nobody can, because it depends on your environment ![]()
The country code should usually be the country you are currently in - due to laws.
Wi-Fi Mode, Bandwidth and channels depend on your devices.
So you need to tell us a bit more about your network ![]()
Of course, but I remember old discussions where someone said to change the country code for best performance (for example) or to change the Bandwidth to 80 and specify the channel for improving signal, and other things like these.
About my network, nothing particular: I have just the flint2 with the fiber connected on the WAN and both WiFi enabled (5Ghz and 2Ghz - guest access is disabled)
