4.7.0 Brume 2 Nordvpn servers missing
I updated my Brume 2 to new 4.7.0 stable and wanted to try out the new NordVPN option for wireguard. I imported my access token, but it is missing servers which can be imported in Glinet UI for Germany. It just shows the first city in the list, which is Berlin. Frankfurt and Hamburg are missing.
If you filter here for Germany, you see they have 3 cities, Berlin, Frankfurt, Hamburg.
But if you import the access token, the Glinet GUI just shows Berlin servers for Germany.
That's - unfortunately - a problem on Nords side:
Then Glinet needs to find a solution to this. Limit the API request so it gets back 5 servers per city or something. I need Frankfurt servers not Berlin.
Since it's still beta, they will take care of it.
You can always use manually created WireGuard profiles.
