4.7.0 Brume 2 not detecting USB flash drive anymore
Updated to 4.7.0 stable on Brume 2 and it does not show my usb 3.0 flash stick anymore, which worked totally fine before and I had used for samba share.
As you see it is still configured from previous fw:
This is the list of optional packages I reinstalled after fw update:
cJSON
coreutils-stat
ddns-scripts-services
ddns-scripts
etherwake
htop
hub-ctrl
iftop
iputils-ping
kmod-crypto-md5
kmod-nft-core
kmod-nft-fib
kmod-nft-nat
kmod-nft-offload
kmod-usb-printer
libcares
libevdev
libmosquitto-ssl
libpcap1
libudev-zero
libusb-compat4
libwebsockets-openssl
luci-app-ddns
luci-app-mosquitto
luci-app-opkg
luci-app-p910nd
luci-app-polipo
luci-app-tinyproxy
luci-app-watchcat
luci-app-wol
luci-base
luci-compat
luci-i18n-base-en
luci-i18n-firewall-en
luci-i18n-opkg-en
luci-lib-ipkg
luci-mod-system
luci-proto-3g
luci-proto-ncm
luci-theme-bootstrap
minicom
mosquitto-client-ssl
mosquitto-ssl
netperf
nping
p910nd
polipo
screen
speedtest-netperf
sshpass
tinyproxy
usbids
usbutils
watchcat
Rebooting device several times did not solve this issue. I then detachted the USB stick and reattached it, and now it is shown again. Seems to be some bug?
This issue seems does not reproduced.
If it appears again, export the syslog. Then, reboot the router and re-plug the U-disk, and export syslog again.
I can only tell what happened to me.
  1. flash drive was working normally, I even was using it the day before I updated to fw 4.7.0
  2. updated to 4.7.0
  3. flash drive was gone after reboot of fw update
  4. rebooting again also did not show the drive anymore
  5. disconnecting drive and reconnecting seems to have make it work again
So something of the update to 4.7.0 caused the device to enter a broken state which even reboot did not fix. I did not have this issue before with the previous fw updates.
