4.7.0 Firmware - MT 6000 Flint 2
Upgraded to this firmware, and already see errors. Under System/Scheduled Tasks, in the time drop downs. I cannot move through the differing times with either a mouse or arrow keys. I can only type the time. It wasn't that way before for this router or my Beryl 1300 or AXT1800. Also, when enabling the LED schedule for off/on time, this seems to cause the router to turn off when the LED goes off.
From which firmware did you upgrade?
MT6000 Flint 2; I selected it from the drop down. 4.7.0
What firmware were you on before you upgraded was the question asked I think.
Did you try reset to factory defaults?
I have Flint 2 and the update went without any problems and I didn't have any errors, but I still did a reset to see what the new version has to offer and just in case the old settings wouldn't cause me any problems
Hi, I'm on the latest firmware 4.7.0 .. and I cannot understand the meaning of my log file, can I post it here to get support !? Sound like my LAN connection is not stable .. micro interuptions.
Thank you
Yeah, post the log file (or at least the lines you don't understand) here
Tue Dec 17 11:19:58 2024 daemon.notice netifd: wan (10225): udhcpc: lease of 10.93.52.232 obtained, lease time 122
Tue Dec 17 11:20:59 2024 daemon.notice netifd: wan (10225): udhcpc: sending renew to 10.93.52.233
Tue Dec 17 11:20:59 2024 daemon.notice netifd: wan (10225): udhcpc: lease of 10.93.52.232 obtained, lease time 122
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[5438]: exiting on receipt of SIGTERM
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[26292]: Connected to system UBus
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[26292]: started, version 2.85 cachesize 1000
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[26292]: DNS service limited to local subnets
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[26292]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[26292]: UBus support enabled: connected to system bus
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq-dhcp[26292]: DHCP, IP range 192.168.8.100 -- 192.168.8.249, lease time 12h
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[26292]: using only locally-known addresses for domain test
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[26292]: using only locally-known addresses for domain onion
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[26292]: using only locally-known addresses for domain localhost
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[26292]: using only locally-known addresses for domain invalid
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[26292]: using only locally-known addresses for domain bind
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[26292]: using only locally-known addresses for domain lan
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[26292]: reading /tmp/resolv.conf.d/resolv.conf.auto
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[26292]: using nameserver 192.168.254.1#53
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[26292]: read /etc/hosts - 4 addresses
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[26292]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq-dhcp[26292]: read /etc/ethers - 0 addresses
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[11292]: exiting on receipt of SIGTERM
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[26373]: Connected to system UBus
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[26378]: started, version 2.85 cache disabled
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[26378]: DNS service limited to local subnets
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[26378]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[26378]: UBus support enabled: connected to system bus
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq-dhcp[26378]: DHCP, IP range 192.168.8.100 -- 192.168.8.249, lease time 12h
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[26378]: using only locally-known addresses for domain lan_chgd
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[26378]: using nameserver 10.96.0.1#53
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[26378]: read /etc/hosts - 4 addresses
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq[26378]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Tue Dec 17 11:21:47 2024 daemon.info dnsmasq-dhcp[26378]: read /etc/ethers - 0 addresses
Tue Dec 17 11:22:00 2024 daemon.notice netifd: wan (10225): udhcpc: sending renew to 10.93.52.233
Tue Dec 17 11:22:00 2024 daemon.notice netifd: wan (10225): udhcpc: lease of 10.93.52.232 obtained, lease time 122
Tue Dec 17 11:23:01 2024 daemon.notice netifd: wan (10225): udhcpc: sending renew to 10.93.52.233
Tue Dec 17 11:23:01 2024 daemon.notice netifd: wan (10225): udhcpc: lease of 10.93.52.232 obtained, lease time 122
Tue Dec 17 11:24:02 2024 daemon.notice netifd: wan (10225): udhcpc: sending renew to 10.93.52.233
Tue Dec 17 11:24:02 2024 daemon.notice netifd: wan (10225): udhcpc: lease of 10.93.52.232 obtained, lease time 122
Hi, thank you.
I'm not an expert obviously, sorry for that.
I'm investigating becouse from time to time the data streaming (while watching videos for example) are interupted .. looks like the LAN gets off/on for some reasons..
The Flint2 is connected to a FWA device, ILIAD/SIM card to the Mobile Network.
It looks like the udhcpc negotiation happen every 122 seconds !?
And the LOG file shows disconnection, or at least it looks so to me ..
Thank you
Luigi
Hello, everyone. Sorry, I haven't replied. I have been working, and had no time for resetting the router. I intend to do that tomorrow, and then post results here. Thanks again.
OK, I completed the re-firmware without saving settings, and everything works fine. The new initialization was improved and nice. I still think there's a bug in the firmware regarding the setting of the times in Scheduled section. I still have to type the time. I cannot use the arrows or the mouse cursor. Nothing except keying in the numbers. Thanks everyone.
