[4.7.0-op24] Known bugs
kernel package version and hash dose not match, which leads to kmods can not be installed.
from the openwrt.org:
Index of /releases/24.10.0-rc2/targets/mediatek/filogic/kmods/6.6.63-1-56564de2705a53e5f6456d5babec92a2/
and from the router:
oot@GL-MT6000:~# cat /etc/openwrt_release
DISTRIB_ID='OpenWrt'
DISTRIB_RELEASE='24.10.0-rc2'
DISTRIB_REVISION='r28161-ea17e958b9'
DISTRIB_TARGET='mediatek/filogic'
DISTRIB_ARCH='aarch64_cortex-a53'
DISTRIB_DESCRIPTION='OpenWrt 24.10.0-rc2 r28161-ea17e958b9'
DISTRIB_TAINTS='busybox override'
root@GL-MT6000:~# uname -m
aarch64
root@GL-MT6000:~# uname -r
6.6.63
root@GL-MT6000:~# opkg list-installed | grep kernel
kernel - 6.6.63~0645ca2e528c1ec9171c95cdd5761b53-r1
Yes so you would need to checkout the same revision and probably pull in
https://git01.mediatek.com/plugins/gitiles/openwrt/feeds/mtk-openwrt-feeds/ master branch.
I not developer :joy:, just trying to install plug-in which required kmod dependency, and i can't find the right version anywhere.
Why does it take so long to release the stable version of 4.7.4? Is it known when it should be released?
After more than 3 months running 4.7.0-op24 Beta (2024-12-09) on GL-MT6000, I noticed a crash:
Oops#1 Part1
<6>[8095406.935559] mt7530-mdio mdio-bus:1f lan3: Link is Up - 1Gbps/Full - flow control rx/tx
<6>[8095406.935586] br-lan: port 2(lan3) entered blocking state
<6>[8095406.949042] br-lan: port 2(lan3) entered forwarding state
<6>[8268006.820548] br-lan: port 2(lan3) entered disabled state
<6>[8268006.820655] mt7530-mdio mdio-bus:1f lan3: Link is Down
<6>[8268019.221839] mt7530-mdio mdio-bus:1f lan3: Link is Up - 1Gbps/Full - flow control rx/tx
<6>[8268019.221867] br-lan: port 2(lan3) entered blocking state
<6>[8268019.235320] br-lan: port 2(lan3) entered forwarding state
<6>[8350718.083627] br-lan: port 2(lan3) entered disabled state
<6>[8350718.083736] mt7530-mdio mdio-bus:1f lan3: Link is Down
<6>[8350729.145903] mt7530-mdio mdio-bus:1f lan3: Link is Up - 1Gbps/Full - flow control rx/tx
<6>[8350729.145927] br-lan: port 2(lan3) entered blocking state
<6>[8350729.159384] br-lan: port 2(lan3) entered forwarding state
<6>[8350729.896795] br-lan: port 2(lan3) entered disabled state
<6>[8350729.896898] mt7530-mdio mdio-bus:1f lan3: Link is Down
<6>[8350732.830374] mt7530-mdio mdio-bus:1f lan3: Link is Up - 1Gbps/Full - flow control rx/tx
<6>[8350732.830400] br-lan: port 2(lan3) entered blocking state
<6>[8350732.843854] br-lan: port 2(lan3) entered forwarding state
<1>[8361768.615719] Unable to handle kernel paging request at virtual address dead000000000100
<1>[8361768.623801] Mem abort info:
<1>[8361768.626788]   ESR = 0x0000000096000004
<1>[8361768.630694]   EC = 0x25: DABT (current EL), IL = 32 bits
<1>[8361768.636178]   SET = 0, FnV = 0
<1>[8361768.639406]   EA = 0, S1PTW = 0
<1>[8361768.642710]   FSC = 0x04: level 0 translation fault
<1>[8361768.647753] Data abort info:
<1>[8361768.650791]   ISV = 0, ISS = 0x00000004, ISS2 = 0x00000000
<1>[8361768.656436]   CM = 0, WnR = 0, TnD = 0, TagAccess = 0
<1>[8361768.661642]   GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0
<1>[8361768.667113] [dead000000000100] address between user and kernel address ranges
<0>[8361768.674400] Internal error: Oops: 0000000096000004 [#1] SMP
<7>[8361768.680128] Modules linked in: gl_mpflow(O) pppoe ppp_async option wireguard usb_wwan rndis_host qmi_wwan pppox ppp_generic nft_fib_inet nf_flow_table_inet mt7915e(O) mt76_connac_lib(O) mt76(O) mac80211(O) libchacha20poly1305 ipt_REJECT huawei_cdc_ncm chacha_neon cfg80211(O) cdc_ncm cdc_ether xt_time xt_tcpudp xt_tcpmss xt_statistic xt_state xt_recent xt_quota xt_pkttype xt_owner xt_nat xt_multiport xt_mark xt_mac xt_limit xt_length xt_hl xt_helper xt_ecn xt_dscp xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_cgroup xt_addrtype xt_TPROXY xt_TCPMSS xt_REDIRECT xt_MASQUERADE xt_LOG xt_HL xt_DSCP xt_CT xt_CLASSIFY usbserial usbnet ts_fsm ts_bm slhc poly1305_neon nft_tproxy nft_socket nft_reject_ipv6 nft_reject_ipv4 nft_reject_inet nft_reject nft_redir nft_quota nft_numgen nft_nat nft_masq nft_log nft_limit nft_hash nft_flow_offload nft_fib_ipv6 nft_fib_ipv4 nft_fib nft_ct nft_compat nft_chain_nat nf_tproxy_ipv6 nf_tproxy_ipv4 nf_tables nf_socket_ipv6 nf_socket_ipv4 nf_reject_ipv4 nf_nat_tftp
<7>[8361768.680310]  nf_nat_snmp_basic nf_nat_pptp nf_nat_irc nf_nat_h323 nf_nat_amanda nf_log_syslog nf_flow_table nf_conntrack_tftp nf_conntrack_snmp nf_conntrack_sane nf_conntrack_pptp nf_conntrack_netlink nf_conntrack_netbios_ns nf_conntrack_irc nf_conntrack_h323 nf_conntrack_broadcast ts_kmp nf_conntrack_amanda nf_conncount mdio_netlink(O) libcurve25519_generic libcrc32c libchacha iptable_nat iptable_mangle iptable_filter ipt_ECN ipheth ip_tables compat(O) cdc_wdm cdc_acm br_netfilter asn1_decoder arptable_filter arpt_mangle arp_tables crypto_safexcel fuse sch_tbf sch_ingress sch_htb sch_hfsc em_u32 cls_u32 cls_route cls_matchall cls_fw cls_flow cls_basic act_skbedit act_mirred act_gact xt_set ip_set_list_set ip_set_hash_netportnet ip_set_hash_netport ip_set_hash_netnet ip_set_hash_netiface ip_set_hash_net ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ipmac ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6table_nat
<7>[8361768.769540]  nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 ip6t_NPT ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 ifb ip6_udp_tunnel udp_tunnel udp_diag tcp_diag raw_diag inet_diag tun ntfs nls_utf8 nls_iso8859_1 nls_cp437 sha512_arm64 sha1_ce sha1_generic seqiv md5 geniv des_generic libdes authencesn authenc uas usb_storage leds_gpio xhci_plat_hcd xhci_pci xhci_mtk_hcd xhci_hcd uhci_hcd ohci_platform ohci_hcd fsl_mph_dr_of ehci_platform ehci_fsl kmwan(O) ehci_hcd gpio_button_hotplug(O) gl_sdk4_tertf(O) gl_sdk4_black_white_list(O) vfat fat exfat usbcore usb_common aquantia mii gl_sdk4_hw_info(O)
<7>[8361768.915512] CPU: 3 PID: 8042 Comm: lua Tainted: G           O       6.6.63 #0
<7>[8361768.922800] Hardware name: GL.iNet GL-MT6000 (DT)
<7>[8361768.927659] pstate: 80400005 (Nzcv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
<7>[8361768.934773] pc : subnet_free+0x804/0xda0 [gl_sdk4_tertf]
<7>[8361768.940250] lr : subnet_free+0x824/0xda0 [gl_sdk4_tertf]
<7>[8361768.945719] sp : ffffffc089993b90
<7>[8361768.949191] x29: ffffffc089993b90 x28: ffffffc080e9d8d0 x27: ffffff8004b582a0
<7>[8361768.956480] x26: ffffff8004b58298 x25: ffffffc07918b500 x24: ffffff8004b58268
<7>[8361768.963770] x23: ffffffc07918b508 x22: ffffffc080e9e1e8 x21: ffffff8007786b40
<7>[8361768.971059] x20: ffffff8004b582a8 x19: dead000000000100 x18: 0000000000000005
<7>[8361768.978348] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000010
<7>[8361768.985637] x14: 0000000000000000 x13: ffffffc089993b90 x12: ffffffc089993b90
<7>[8361768.992926] x11: 00000000ffffffd0 x10: ffffffc089993b60 x9 : ffffffc089993b90
<7>[8361769.000215] x8 : 000000000000013b x7 : 0000000000000036 x6 : 0000000000000008
<7>[8361769.007504] x5 : ffffffc080ab31e0 x4 : ffffffffffffffff x3 : 0000000000000000
<7>[8361769.014793] x2 : ffffffc080b48e38 x1 : 0000000000000114 x0 : 000000000000013b
<7>[8361769.022083] Call trace:
<7>[8361769.024689]  subnet_free+0x804/0xda0 [gl_sdk4_tertf]
<7>[8361769.029812]  seq_read_iter+0xdc/0x488
<7>[8361769.033637]  seq_read+0x78/0x98
<7>[8361769.036938]  proc_reg_read+0xb0/0x100
<7>[8361769.040762]  vfs_read+0xa4/0x278
<7>[8361769.044150]  ksys_read+0x60/0xe8
<7>[8361769.047537]  __arm64_sys_read+0x20/0x30
<7>[8361769.051531]  invoke_syscall.constprop.0+0x54/0xf0
<7>[8361769.056394]  do_el0_svc+0x44/0xc8
<7>[8361769.059867]  el0_svc+0x18/0x50
<7>[8361769.063083]  el0t_64_sync_handler+0x118/0x128
<7>[8361769.067597]  el0t_64_sync+0x150/0x158
<0>[8361769.071420] Code: 95c49f07 f9400273 eb14027f 54000180 (f9400263)
<4>[8361769.077666] ---[ end trace 0000000000000000 ]---
Panic#2 Part1
<3>[8361769.097831] pstore: backend (ramoops) writing error (-28)
<0>[8361769.103389] Kernel panic - not syncing: Oops: Fatal exception
<2>[8361769.109288] SMP: stopping secondary CPUs
<0>[8361769.113369] Kernel Offset: disabled
<0>[8361769.117014] CPU features: 0x0,00000000,00000000,1000400b
<0>[8361769.122480] Memory Limit: none
I think I found a bug.
In the GL interface I can't select channels higher than 128 on 5Ghz, even though in my country it is allowed to use up to 140 at least, while from luci it is possible.
Hi, when we can get a new beta/final op24 firmware version? the last version available to download is more than 4 months old...
Bruce said in another post, this week.
Finally, the first minor update to OP24.10 has been released. I hope this (24.10.01) will be used as the based for the next MT6000 OP24 release.
I don't think so...
If they will release a new version this week, it will probably be an OpenWRT version from, at least, 2 months ago.
That's sounds good but I wouldn't put my hopes on that :thinking:
65 posts were merged into an existing topic: [4.7.5-OP24 Known Bugs]
Well, not sure if we should close this thread. I don't know about the current firmware situation but as I guess and know about the GL firmware ... pain ...., not all devices are yet on 4.7.5-op24 or even able to get there?
But just in case, bug reports about 4.7.5 should go there:
