4.7.0 The WireGuard configuration file is broken when IPv6 is enabled
Address = 10.0.0.2/24,fd0
This line is part of the WG config file, which breaks the configuration file.
Removing the IPv6 (,fd0) makes the config file and VPN work fine. Changing the IPv6 to fd0:: makes the configuration importable, but the VPN does not work.
I have the same problem
I can confirm this issue on my Flint 2 with 4.7.0 (non-op24). It is necessary to manually edit the address within the config file. After this step the configuration works flawlessly.
This issue we are aware, the codes have been updated, and improve it in the next version firmware.
Thanks for solving the issue, when can we expect the firmware with the fix to be released?
