4.7.2 beta1 version
No SSH access to LuCi with my computer's SSH rules... it seems that router has too low (and so too old) specifications, so my computer is not ready to take this risk...
  1. You need to inform the model of your device
  2. SSH require a very low processing, almost no processing at all.
    I don't believe the hardware specification is the issue.
SFT-1200
No I am talking about probably the dropbear version, not the hardware
Is it ready to accept an ED25519 key ?
I am advised to install openssl instead of dropbear but it is too complicated for me
More precisely, it is dropbear which is not able or willing to handle ED25519 key, is it possible to upgrade it ? or bypass this ?
Firmware 4.7 is based on OpenWRT 23.02
Which dropbear version do you have installed and which one do you need?
https://www.reddit.com/r/openwrt/s/MXHjwYVqVn
Opal firmware version 4.7 is based on 18.06
Dropbear 2017.75-9 is my version
For reddit I am blocked for some network issue
Still no solution ?
And how must I do to upgrade this beta version ? Am I stuck forever with it ?
