[4.7.5-OP24] Known Bugs
Sorry, I think there may be some oversight.
I can confirm that there is no such problem in the beta and release versions of v4.8. And in theory, all 4.8 firmwares use the same set of code.
I am also a little confused why the op-24 v4.8 still has this issue. I will push for some inspections.
Thank you.
I can save the config, but I am not able to start the VPN. With the MT3000 this problem doesn't exit.
@teleney, AdGuardHome isn't working with the Flin2 op-24 v4.8. It starts up, but doesn't process DNS requests. Reverted to v4.7.5 and AdGuardhome works like charm.
Just received confirmation that there is an issue with the Flint2 op-24 v4.8 firmware, which affects the operation of the VPN.
The relevant colleagues are working on it. I believe that a new firmware will be available soon, and it will have the same features as other v4.8 firmwares.
@teleney, I just downloaded and installed the newest beta version 4.8.0-op24 Beta2025-07-29.
This one, opens the OpenWRT GUI after start, but not the GL-inet GUI.
Could it be that your browser has cached a previous version of the page? You could try clearing your cache.
During pre-release testing, our QA team didn’t encounter this issue.
That said, I’ve forwarded your findings to the relevant team.
Thanks
I made a clean install, and now, the GL-Inet GUI shows up. It might have been a cashing issue.
For 4.8.0-OP24, we should continue with a new thread.
Maybe this one : Beta 4.8.0 op24 issues - #61 by Rainbow99
It wasn't a cashing issue. I tried another browser, and the same problem appeared. I sent the config output to your colleague in a private message.
Thank you for your enthusiasm and support. My colleague will work with you to identify and resolve the issue. :grinning_cat_with_smiling_eyes:
