That's not reassuring ![]()
I hope there'll a stable version on day... and in concordance with the OpenWRT version (with all packet like the one for the firewall, the new package manager, etc...)
Astrowarp is missing from this version
Update installed, but when I install packages from luci I get these errors, even though the packages apparently still install.
Collected errors:
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.47~5f888a243508bd63116c3c6987914d47-r1) for kmod-nf-reject6
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.47~5f888a243508bd63116c3c6987914d47-r1) for kmod-nf-ipt
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.47~5f888a243508bd63116c3c6987914d47-r1) for kmod-nf-log
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.47~5f888a243508bd63116c3c6987914d47-r1) for kmod-nf-log6
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.47~5f888a243508bd63116c3c6987914d47-r1) for kmod-nf-ipt6
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.47~5f888a243508bd63116c3c6987914d47-r1) for kmod-ipt-core
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.47~5f888a243508bd63116c3c6987914d47-r1) for kmod-ip6tables
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.47~5f888a243508bd63116c3c6987914d47-r1) for kmod-nfnetlink
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.47~5f888a243508bd63116c3c6987914d47-r1) for kmod-nf-conntrack
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.47~5f888a243508bd63116c3c6987914d47-r1) for kmod-nf-conntrack6
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.47~5f888a243508bd63116c3c6987914d47-r1) for kmod-nf-nat
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.47~5f888a243508bd63116c3c6987914d47-r1) for kmod-crypto-hash
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.47~5f888a243508bd63116c3c6987914d47-r1) for kmod-crypto-crc32c
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.47~5f888a243508bd63116c3c6987914d47-r1) for kmod-lib-crc32c
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.47~5f888a243508bd63116c3c6987914d47-r1) for kmod-nft-core
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.47~5f888a243508bd63116c3c6987914d47-r1) for kmod-nft-compat
* pkg_hash_check_unresolved: cannot find dependency kernel (= 6.6.47~5f888a243508bd63116c3c6987914d47-r1) for kmod-nf-conntrack-netlink
Updated to 4.7.5 with clean config (did 2 resets) but I still can't login to Mullvad. Anyone experiencing the same problem?
EDIT: It works now after I manually added a WG config. I dont know how it relates to the problem but after adding a config, it let me logged in on my account.
Does anyone know if its possible to install qosmate on 4.7.5-op24?
R&D is urgently fixing this issue and will release an newer version later, including the AW.
This issue does not reproduce locally MT6000 with 4.7.5-op24, login ok to Mullvad in GL GUI at first time when it upgraded firmware.
It may have something to do with the network.
Im not sure either. Its in a fresh state and no other active application was running (i.e. adguardhome). The network works fine too. I noticed that it doesn't add device key on my account too. Logs doesn't seem to provide any helpful information either. However, it works fine now so still thanks for trying to find the root cause.
Im curious too
What plugin(s) is being installed?
Try to compile this plugin on the 4.7.5-op24, will add to the GL repo if it works.
well, the 4.7.5-op24 has been pulled from DL website now.
Wow, that's a statement, I would say. There must have been going something very wrong. Let's see, when they release a new version. @bruce, any insight about this?
With OP24 4.7.5 AdguardHome stats are not populated. I am using the latest version from Github. Version: v0.107.60
I tried 4.7.5-op24 and canβt seem to install some kmods due to kernel version mismatch. Reverted back to 4.6.6-op24. Hope they fix it after they put it back up.
That says a lot ![]()
I noticed a new version was released now.
Any of my reported issue was fixed?
I have recently purchased my Flint 2 and was running v4.7.0-op24 until yesterday.
I updated to v4.7.5-op24 (dated 16/4) yesterday and all was well.
Today I find that the version I use was faulty and deleted, replaced by one dated 18/4.
I updated to the 18/4 version - and software cannot be added via Luci.
So things like Samba, irqbal, sqm are not able to be installed.
I had to go back to my saved copy of v4.7.5-op24 dated 16/4 and was able to get the software I needed.
Now I see that the 18/4 version is problematic for others too, but this will not be fixed for a week!
I don't think that is very good.
Maybe reinstate the 16/4 version availability for those that find it less problematic than the 18/4 version - like myself - and replace both next week with something that works for everyone.
Maybe something based on 24.10.0 rather than 24.10.RC5...
The problems in the new version have been fixed, but now the opkg repositories are missing luci languages ββand many other packages, including luci apps.
Also compared to 4.7.0 the few packages in the repository are older in version.
Whether some custom firewall rules have been manually added. Regarding custom added firewall rules are not GL GUI functions, these rules may not be adapted to for firmware upgrade at present.
The firmware has been updated from 4.7.0 to 4.7.5, and the USB drive has not been manually re-plugged. After the router upgraded and restart is completed, the USB drive can be automatically identified. This issue has not been reproduced.
The plugins volume from GL repo is being improved.
Since the newer firmware kernel has been updated, the plugins need to be updated at the same time. Please wait.
