[4.8.0 Beta] Firmware (MT6000/3000) questions
Hello, I see the new 4.8.0 beta fw for MT6000 and 3000.
Based on changelog:
Added VPN multi-instance, allowing support for enabling multiple VPN clients at the same time.
I ask if this feature is the requested "double vpn tunnel" for use 2 server in 1 connection:
PC --> server 1 --> server 2 --> internet
or is another feature like:
PC1 --> server 1 --> internet
PC2 --> server 2 --> internet
I see the infamous kill switch toggle for every vpn tunnel, very good!
Thanks a lot for your effort gl.inet team! :wink:
It's the latter one. Parallel for multiple instances is not cascaded.
Ok, thanks.
But please can you consider to add the first (cascaded) option? :smile:
Hello, can you describe in detail the specific use scenarios and purposes of the cascade like PC-> server1-> server2-> Internet?
A configuration like:
PC --> ovpn (or wg) server 1 --> ovpn (or wg) server 2 --> internet
is useful for who needs an extra layer of encryption and protection (like journalist or political activist)
if this solution is possible, please try to implement in next firmware. Thanks.
Ok, thanks for your feedback. I have recorded it.
Thank you!
4.8.0 is it based on openwrt version 21?
yes op21
