4.8.0 Snapshot bugs
Hello guys,
I installed today the snapshot and its seem the dnsmasq is bugged inside.
Is only working with DNS setup on automatic. If i try any other setting for the excluded clients from any Wireguard connection the dns is not working.
UPDATE: DoT is working , DoH no
I see couple of more bugs in Flint2. Beta version 4.8.0.
When you are running vpn on lan and guest but another ssid on just wan.
  1. There are dns leaks happening in non vpn ssid.
  2. Terminating vpn connection breakage ends internet on all others too. Just happened once.
The selected DoH server may be temporarily unreachable. You can try switching to a different one.
How do you configure another ssid? Do you create a new network?
I have used new firewall, new network and new ssid.
But i think it happened due to overide dns was on. It is resolved once i turned off override.
DNS issue still exists in the new Snapshot. To work must use automatic dns. Everything else crash the dns
I didn't reproduce. will PM you to get logs and other info.
Each vpn tunnel has its own dnsmasq instance, I guess it needs to add a section in /etc/config/dhcp accordingly.
