Thanks, this is what we should do.
But I'm also very sorry for causing you some inconvenience.
a bit strange issue and cannot be reproduced it in my router locally.
Glad to hear the issue is resolved now, enjoy it!
I updated to 4.8.3 and have a similar issue now. I have changed nothing except updated the firmware. AG Home is also on in my setup. I can connect to the VPN, but I can no longer access any IP directly; servers, printers, etc… My browser is greeted with a “NSURL ErrorDomain”
Disable AGH and use my script to update AGH:
Re-enable it afterwards.
@admon Thanks for the reply. You believe this has to do with AGH and not the VPN/Firmware update? Maybe I can disable AGH to test beforehand?
Afaik the problem is AGHs Multipath usage which has some issues in some GL firmwares.
My script disables it by running:
disable_multipath_tcp() {
if ! grep -q 'procd_set_param env GODEBUG=multipathtcp=0' /etc/init.d/adguardhome; then
sed -i '/procd_set_param stderr 1/a\ procd_set_param env GODEBUG=multipathtcp=0' /etc/init.d/adguardhome
fi
@admon even if ADH is disabled?
Nah, but after disabling AGH, make sure to restart all devices so there are no weird cached entries anymore.
I solved my issue here
