Can you list an Amazon URL for external Antenna and cable for the 4G Smart Modem? I would like to get the best signal possible from this unit…it works well now, but I tend to be in some areas with less than ideal signal…
Thank you.
Thank you.
Sorry we don’t have such a list. But as long as the connector is compatible it works.
I found the following which I do believe are correct parts…
Antennas
Cables
I am thinking that should do.
-DJ
