Yes it will work. For the v2 firmware there is a guide on the NordVPN page here:
But it is recommended that you upgrade to the v3 firmware as soon as you get the router. The steps will be similar and if you have and issues you can write here in the forums
Make sure you get the newer Mifi with the EP06 modem for best performance.
