Can anyone recommend me 5G NSA USB module for Flint?
I also need ability to change IMEI of the 5G module
thanks in advance
thanks in advance
Please have a look the GL-M2 5G Dev Board
Does this allow changing IMEI?
Is this compatible with Any OpenWRT router with USB port?
(I dont have GL.iNET router)
Wonder what happens if I put my phone IMEI on modem?
Support input AT commands.
Relevant drivers need to be installed.
Usually nothing will happen, but you can try.
Please backup current stock IMEI number.
any link to the drivers?
can you explain the process?
I have openWRT router with USB port,
planning to buy GL-M2
Here you go:
