Hi, the package MWAN3 is really needed or I can safely remove because I use only one WAN connection? I want to remove it because there are continuous ICMP echo request (4 ping every 5 seconds ) towards Google DNS and OpenDNS.
Cheers Raphael_
Cheers Raphael_
Yes, many already complained of the same problem calling google)!
You can do a search but from my notes:
Disable Mwan3 (pings Google) -
opkg remove luci-app-mwan3 # Luci > system > software
rm /etc/config/mwan3 # can just delete this file in WinSCP
ssh to the router, issue those commands.
mwan3 stop
opkg remove mwan3 luci-app-mwan3
Thanks a lot @kyson-lok and @glitch
Cheers Raphael_
