Hello! I was wondering if anyone has tried to configure 802.11r (fast transition) on the AX1800 (Flint)? I have two of these (might get a 3rd if this works) and would like to enable ft, but it is not listed in luci. I thought I would ask before I tried configuring it via /etc/config/wireless in case it isn’t supported in the driver or is known to be buggy. Thanks!
hi,
have you seen this?
https://parkercs.tech/enabling-802-11r-fast-roaming-transition-on-openwrt/
That guide is for vanilla OpenWRT and does not work with these devices (for one there are no ‘wpad’ or ‘wpad-openssl’ packages). On vanilla OpenWRT one can enabled 802.11r with a simple checkbox in LuCI.
did you enable encryption, might need to enable?
well, that is strange, just WEP
based on that clue, someone more experienced would know.
but for me,
