One question. I have a lot of packages to update in the Plugin section without having installed nothing from the OpenWRT repository:
They come from that sources:
Are they safe to update?
No.
Never update any plugins. It will brick your router mostly.
Ok, I will take in account. Thanks!!
Don't upgrade that if you did not install it by package manager.
Technically the updates shouldn't exist, they should be in the latest release for the Marble.
What I mean by that is the Marble stock firmware is based on QSDK12, and when the stock firmware was compiled, someone chose to install feeds before updating feeds, because these three packages should be in the stock firmware.
Perhaps Qualcomm adds the default repos in QSDK when compiling proprietary sources, hence this issue.
