Tried firmware 4.2 (snapshot) and 4.0 (factory reset) with no change in result. Log from test with 4.0 below:
Fri Jan 6 15:20:26 2023 daemon.notice netifd: Interface ‘wgclient’ is setting up now
Fri Jan 6 15:20:26 2023 daemon.info dnsmasq[11784]: exiting on receipt of SIGTERM
Fri Jan 6 15:20:33 2023 daemon.info dnsmasq[1559]: Connected to system UBus
Fri Jan 6 15:20:33 2023 daemon.info dnsmasq[1559]: started, version 2.85 cachesize 150
Fri Jan 6 15:20:33 2023 daemon.info dnsmasq[1559]: DNS service limited to local subnets
Fri Jan 6 15:20:33 2023 daemon.info dnsmasq[1559]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Fri Jan 6 15:20:33 2023 daemon.info dnsmasq[1559]: UBus support enabled: connected to system bus
Fri Jan 6 15:20:33 2023 daemon.info dnsmasq-dhcp[1559]: DHCP, IP range 192.168.9.100 – 192.168.9.249, lease time 12h
Fri Jan 6 15:20:33 2023 daemon.info dnsmasq-dhcp[1559]: DHCP, IP range 192.168.8.100 – 192.168.8.249, lease time 12h
Fri Jan 6 15:20:33 2023 daemon.info dnsmasq[1559]: using only locally-known addresses for domain test
Fri Jan 6 15:20:33 2023 daemon.info dnsmasq[1559]: using only locally-known addresses for domain onion
Fri Jan 6 15:20:33 2023 daemon.info dnsmasq[1559]: using only locally-known addresses for domain localhost
Fri Jan 6 15:20:33 2023 daemon.info dnsmasq[1559]: using only locally-known addresses for domain invalid
Fri Jan 6 15:20:33 2023 daemon.info dnsmasq[1559]: using only locally-known addresses for domain bind
Fri Jan 6 15:20:33 2023 daemon.info dnsmasq[1559]: using only locally-known addresses for domain lan
Fri Jan 6 15:20:33 2023 daemon.info dnsmasq[1559]: reading /tmp/resolv.conf.d/resolv.conf.auto
Fri Jan 6 15:20:33 2023 daemon.info dnsmasq[1559]: using nameserver 192.168.42.129#53
Fri Jan 6 15:20:33 2023 daemon.info dnsmasq[1559]: read /etc/hosts - 4 addresses
Fri Jan 6 15:20:33 2023 daemon.info dnsmasq[1559]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Fri Jan 6 15:20:33 2023 daemon.info dnsmasq-dhcp[1559]: read /etc/ethers - 0 addresses
Fri Jan 6 15:23:19 2023 daemon.info dnsmasq-dhcp[1559]: DHCPREQUEST(br-lan) 192.168.8.153 e4:95:6e:44:26:10
Fri Jan 6 15:23:19 2023 daemon.info dnsmasq-dhcp[1559]: DHCPACK(br-lan) 192.168.8.153 e4:95:6e:44:26:10 GL-MT300N-V2-610
Fri Jan 6 15:27:43 2023 daemon.info dnsmasq[1559]: exiting on receipt of SIGTERM
Fri Jan 6 15:27:51 2023 daemon.info dnsmasq[14850]: Connected to system UBus
Fri Jan 6 15:27:51 2023 daemon.info dnsmasq[14850]: started, version 2.85 cachesize 150
Fri Jan 6 15:27:51 2023 daemon.info dnsmasq[14850]: DNS service limited to local subnets
Fri Jan 6 15:27:51 2023 daemon.info dnsmasq[14850]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Fri Jan 6 15:27:51 2023 daemon.info dnsmasq[14850]: UBus support enabled: connected to system bus
Fri Jan 6 15:27:51 2023 daemon.info dnsmasq-dhcp[14850]: DHCP, IP range 192.168.9.100 – 192.168.9.249, lease time 12h
Fri Jan 6 15:27:51 2023 daemon.info dnsmasq-dhcp[14850]: DHCP, IP range 192.168.8.100 – 192.168.8.249, lease time 12h
Fri Jan 6 15:27:51 2023 daemon.info dnsmasq[14850]: using only locally-known addresses for domain test
Fri Jan 6 15:27:51 2023 daemon.info dnsmasq[14850]: using only locally-known addresses for domain onion
Fri Jan 6 15:27:51 2023 daemon.info dnsmasq[14850]: using only locally-known addresses for domain localhost
Fri Jan 6 15:27:51 2023 daemon.info dnsmasq[14850]: using only locally-known addresses for domain invalid
Fri Jan 6 15:27:51 2023 daemon.info dnsmasq[14850]: using only locally-known addresses for domain bind
Fri Jan 6 15:27:51 2023 daemon.info dnsmasq[14850]: using nameserver 103.86.99.100#53
Fri Jan 6 15:27:51 2023 daemon.info dnsmasq[14850]: using nameserver 103.86.96.100#53
Fri Jan 6 15:27:51 2023 daemon.info dnsmasq[14850]: using only locally-known addresses for domain lan
Fri Jan 6 15:27:51 2023 daemon.info dnsmasq[14850]: read /etc/hosts - 4 addresses
Fri Jan 6 15:27:51 2023 daemon.info dnsmasq[14850]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Fri Jan 6 15:27:51 2023 daemon.info dnsmasq-dhcp[14850]: read /etc/ethers - 0 addresses
Ok I proved there is nothing wrong with the firmware. The attached log file shows a successful connection. Could you please look and tell me what is different with this server? I need to use a different server but this is the only one that connects. Thanks.
Final solution - I was extracting the server public key incorrectly. So my config files were incorrect. This caused the router to hang while attempting to connect to the server.
