I have a Beryl AX connected to my 4G router via Ethernet. Is there any way to access my 4G router's admin page when I am connected to the Beryl AX via WiFi?
Just enter the LAN IP of your 4G router, it should work out of the box.
It only worked once. Then, no access.
Did you enable VPN on your Beryl by chance?
Yes, and I enabled remote access LAN in the VPN client.
This won't help because this option is for the devices connected by VPN instead of connected to your LAN.
For accessing your 4G router you should change either the VPN routing policy by excluding the IP of the 4G router or you need to disable VPN for access.
Then, I cannot use "VPN policy based on the client device", right?
That's correct.
Will enabling Allow Access WAN help?
Yep, totally.
