Can you describe your access method?
If you access via LAN, you can try to enter the full domain name https://glkvm.local
Or some mobile phones do not support mdns. You can try to access using the IP address.
If you need to access remotely on a mobile phone, you can try tailscale+chrome
I am able to get to the WebUI and login just fine. The issue is that where there should be display output showing, there is just a white-space. This problem does not occur when accessing via my laptop. From an Android tablet, or smartphone, the only browser I can get to work is Samsung Internet(!). However, interacting with the display is non-functional.
I note that GLKVM is based on PIKVM. On PiKVM, the recommendation for access from Android is to enable a VNC server built in to PIKVM. The same VNC server does not seem to be a part of GLKVM, so I wanted to check if there is a different access method recommended for Android users with the Comet.
The display output does not appear at all on most android browsers. I have got display output when using Samsung Internet browser, however I am unable to interact.
I suspect that we either need a UI optimisation for smartphone & tablet browsers, or a dedicated app for Android and iOS, or the VNC server option (PIKVM offers this).
Not at all, merely that certain capabilities such as rendering the screen output don't seem to be supported in certain android browsers. Switching between desktop or mobile modes makes no difference.
Accessing on lan rather than remote over wan makes no difference.
This post interesting to me and I tested little. I can see the remote screen (Windows PC) from Pixel tablet (Google Chrome) on my local network.
I guess you need to adjust screen resolution, for example (for my case), set 1920x1080 and select "Duplicate these screen" at Windows, then select same resolution at EDID of GLKVM.
I can also observed some of resolution set shows completely white, red, or something like that, so, choosing right resolution might be a key.
Anyway, this is my opinion though, at the moment it does not seem to have been designed with access from mobile devices in mind, and the usability feels completely unusable. (Virtual Keyboard key input works, but look at the size of the keyboard...)
I am trying to access kvm via cell Android tailscale using 100 IP address. As above not able to get any display other than menus. Target computer white .
Using a Samsung S10 tab+ with Brave I can see the screen on my host computer, however my paired mouse does not move the mouse pointer on the remote computer, only locally.
As a workaround I use the pen which seem to work better.
Any news on this? I too only get a blank display, just the ui, on any android browser but brave. The mouse doesn't work on brave android, doesn't follow the mouse on either relative or absolute. There is also no way to right click or scroll or drag with a touchscreen.
Any info at all on android support? App in the works? UI fix comming? Browser fix? Anything? Really disapointing in the lack of comunication here.
As someone that almost exclusively uses android devices, this really isn't living up to expectation. Browser support at the very least seems like it would be a top priority to fix, asap.
