I just bought a smart mini router GL-AR150-609. I’ve set it up as a repeater, wirelessly connected to my home router. I’ve also created static ip addresses for each of the devices that will be connected in the LAN. Now I want to be able to connect to my home network (not the gl-ar150 repeater router) and I want to open a port for each device in my LAN so that I can individually access each device from my home network. I’d like to be able to access each individual device via ssh, and I don’t want to set up through ddns. I’ve tried several different settings however, have not been able to set this up.
My repeater router ip address is 10.0.0.0
My device in the LAN is 10.0.0.185 (it’s a raspberry pi)
The gl-ar150-609 IP address from the router is 192.168.1.106
In the main gl inet homepage for the repeater router, I have enabled WAN Access to port 8008, then in the advanced settings under Network->Firewall->Port Forwards, I have added a new port forward with Protocol TCP+UDP, External Zone is WAN, External Port is 8008, Internal Port is 8008, Internal Zone is LAN, and Internal Port Address is 10.0.0.185 (my devices ip). After adding this and saving changes, I tried to ssh into the device:
ssh -p 8008 pi@InternetIp
Where InternetIp is my internet’s IP address.
This did not work. Maybe I’m not using the right ssh command or ip address. I also tried opening port 22 on the router by adding port 22 to the “Open ports on router”. This also did not help.
Is there something I’m missing? Can you help in directing me how to ssh into a device on the LAN network from my WAN network having a repeater router set up.
Thanks
Rachel
