How to access LAN devices on GL-MT300N-V2 running WG client from WG server side LAN?
Allow Access Local Network is enabled!
If I connect from client side all is good I can reach LAN devices on server side, but when I want to reach LAN devices connected to GL-MT300N-V2 from server side LAN it is not accessible!
Yes, in remote location I have mobile router connection with CGNAT so no port forwarding. I need to run camera that is routed to my main networks NVR, solar controller for monitoring from my main network and one PC for bandwidth sharing that uses internet from mobile network.
Currently camera and PC is working as intended but I can’t reach solar controller and PC remotely.
For now I’m using mobile router because all usb sticks are only cat4 so upload bandwidth is a bit too low but router is cat6 that gives sufficient upload bandwidth.
Remote location
192.168.11.1 mobile router LAN
*192.168.11.2 PC
*192.168.11.3 Controller
192.168.11.10 Mango VAN
192.168.50.1 Mango LAN
192.168.50.150 Camera
192.168.2.8 WG client
*I moved PC and controller to mango LAN
192.168.151 PC
192.168.152 Controller
but it still is not accessible from server side
Main network
192.168.2.1 WG server
192.168.1.1 main LAN and NVR
I found that if there is VPN policy for specific device to use VPN enabled, mango is not accessible from main LAN anymore, if policyes are switched off Mango GUI is available again.
Is there any way to make this work?
