Access Luci in access point mode
This is for a MT6000. I updated to 4.7 beta. Accessing Luci in access point mode gives 404. Is this by design or a bug in 4.7?
Luci can be found on port 8443 now.
hmm. that's not working either.
Maybe it is a bug with 4.7?
I have a second router Flint 2 with access point mode. I have access only GL UI page but not luci UI. That's is correct
P.s yes 4.7 beta on both routers
What URL does the GL GUI shows for advanced (luci)?
I thought 4.7 beta was supposed to be on a more recent openwrt. But it appears it's on 21.02
No, only the -op24 firmwares are more recent..
8080 port, can't connect .
I installed the -op24 most recent and saw quite a bit slower wifi. Is that using the open source driver? Hard to keep track of what's what. 4.6 release candidate is based on OWRT 24 but 4.7 beta is based on OWRT 21.02? What's up with that?
There are two main firmware branches:
The usual one, based on OpenWrt 21
The -op24 one, based on OpenWrt 24
Each branch has its own release candidates, betas and released firmwares.
ok. it sounded like the -op24 branch was using the MT SDK but my wifi speeds were quit a bit slower compared to 4.7 (usual one). Is -op24 using the open source driver or the MT driver?
I chose not to reset the settings when going from 4.7 back to 4.6.6 so not sure if that had something to do with it. I did that because I didn't really want to reset it up as an AP
