I’ve just got an AR300M because my wifi signal at university is really bad. I have tried to set it up and the ethernet pass through works well however, when I try to connect a device on the access point setup by the ar300m I get a message saying that personal access points are not allowed on my network. However when I use my laptop(connected to ethernet) as an access point it works fine. Is there a way to fix this?
