Hi, i have a curiosity,
If i disable ssh access, is there any method to access to files or i need to reflash?
SSH, or Secure SHell, only gives you a terminal connection and not direct file system access.
For file system access, the best way is to install an sftp server and use an sftp client on your pc.
hi @bluewavenet,
I did not explain myself…
If i lost SSH password or disable service, if there is an alternative way to access on system? through uboot? through serial?
you can access through serial any time.
You can flash the firmware using uboot failsafe: Overview - GL.iNet Docs
@alzhao, is possible to disable access through serial?
disable this row on initab
#::askconsole:/usr/libexec/login.sh
prevent serial access?
