Access usb drive through ftp
I am using a GL.iNet GL-MT6000 and can use network storage ( Network Storage ) just fine, through DLNA.
I was hoping I'd be able to access the usb drive through ftp at e.g., /mnt, but I cannot find it. Is it possible to access the usb stick through ftp, and is it possible to access it through ftp while still using the DLNA feature?
Thanks!
Why do you require to the FTP?
You can install the plugins 'vsftpd' and enable the FTP in the Luci. It is supposed to not affect the DLNA.
I wanted to enable ftp to be able to downstream files into that key without having to unmont / unplug / replug it. It work flawlessly, thanks a lot!
guys, how do you use a dlna server in flint 2? What plugin should I use?
Its already installed, you need to enable it in the settings.
It's in https://<router ip address>/#/nasview
