Accessing UBoot env from user space
My AR-300m ("Shadow") can read its U-Boot environment from Linux with the fw_printenv command after I set the /etc/fw_env.config to:
/dev/mtd1 0 0x10000
However, I cannot find any information on the proper fw_conf.config for the AR750S ("Slate")
#fw_printenv
Warning: Bad CRC, using default environment
Has any managed to get this working?
Strangely:
hexdump /dev/mtd1
shows the dev paritition is erased to All 0xff's
whereas on the Shadow, it contains the env variables.
Both units /proc/mtd indicate that the u-boot-env should be
/dev/mtd: 00010000 00010000 "u-boot-env"
I'm stumped...
Both routers are running 19.07.7 from NAND flash
Is the /dev/mtd1 partition usually erased?!
The partition is usually erased. If no data in this partition, uboot will just use default values.
Are you able to write using fw_setenv?
