Accidentally inserted SIM into SD / TF card slot on Spitz AX-3000
Has anybody done this before? Any idea how I can get it out? Tried with tweezers and it went in further. :frowning: I might have to take it apart.
In other news the router (prior to this) is completely unresponsive and doesn't respond to anything, including the physical reset button :thinking:
Have to use a needle to get it out carefully.
Thanks. I will try very carefully. It was a very silly mistake :slight_smile:
Edit: I got it! Thank you!!!
