Acess Modem Webpage?
How do I access my modem's webpage on 192.168.100.1 using Flint 2 (MT6000? Is this a configuration that needs to be added?
We don't seem to have this page
What do you want to see?
The page is not on the router, but on the Modem.
I’m trying to check on the modem logs if needed without needing to disconnect the router. Also it would be useful to reset it remotely by accessing the webpage instead going to the Modem and pressing the reset button.
This worked on my old router using OpenWRT, but after replacing it with the Flint 2, I’m no longer able to access it.
Please check the modem interface IP of the router, if it obtained IP 192.168.100.0/24, only then can access the webpage 192.168.100.1
Are you using VPN client on MT6000?
If yes it will shield your modem. In this case, in the vpn client settings, enable "Allow Access WAN".
I ended up getting a new modem from my ISP which may have disabled this feature. Tried adding the modem interface on OpenWRT page but still did not work.
https://openwrt.org/docs/guide-user/network/wan/access.modem.through.nat
I do have VPN client configured, but not using it so it’s been disabled. Honestly not sure what’s going on since it use to work on OpenWRT.
Not sure if I’ll be able to figure this out anymore since the new modem doesn’t appear to have a webpage after upgrading my internet.
Thanks for the help though.
