I have a main network driven by a UNIFI UDM router that is connect to my primary ISP over optic fiber and also connect to a GLinet AR750 as a secondary network (via a LTE Hotspot)
This setup is always on and eats quite a bit of my DATA even if the UNIF router is not in FailOver mode.
I would like to find a way to send a “Connect” or “Disconnect” command to the AR750 as I don’t want it to always be connected to eliminate LTE usage if not necessary but only connects it if my network primary line drop on my main router.
Is there a command that can be sent to the GLinet AR750 to activate (connect) to my hotspot or deactivate (disconnect) from my hotspot
thanks for any help
