Adblock protocol 86dd is buggy, dev br-lan
GL.iNet GL-MT6000 - v4.7.5-op24 I installed adblock and I get this error, is there a solution?
Wed Apr 30 17:23:14 2025 daemon.info dnsmasq[1]: exiting on receipt of SIGTERM
Wed Apr 30 17:23:14 2025 daemon.err procd: Got unexpected signal 1
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: started, version 2.90 cachesize 1000
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: DNS service limited to local subnets
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset nftset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: UBus support enabled: connected to system bus
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq-dhcp[1]: DHCP, IP range 192.168.9.100 -- 192.168.9.249, lease time 12h
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq-dhcp[1]: DHCP, IP range 192.168.8.100 -- 192.168.8.249, lease time 12h
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using only locally-known addresses for test
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using only locally-known addresses for stbg.stanbicbank.co.zw
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using only locally-known addresses for powa.co.zw
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for media.discordapp.net
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for latency.discord.media
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for gateway.discord.gg
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for cdn.discordapp.com
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for cinema-rrs-eu.hicloud.com
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for discordstatus.com
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for discord.media
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for discord.gg
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for discord.com
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for discordapp.net
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for discordapp.com
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for updates.discord.com
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for v10.events.data.microsoft.com
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for s.youtube.com
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for ro.info.lgsmartad.com
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for ro.lgrecommends.lgappstv.com
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for settings-win.data.microsoft.com
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for m.yap.yahoo.com
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for mail.yahoo.com
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for app.melcloud.com
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for origin.com
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for speedapp.io
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for nvidia.tt.omtrdc.net
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for production.receiver.melcloud.com
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for static.twitchcdn.net
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for gql.twitch.tv
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for api.twitch.tv
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using standard nameservers for cvp.twitch.tv
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using 247545 more local addresses
Wed Apr 30 17:23:15 2025 daemon.info dnsmasq[1]: using 31 more nameservers
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: reading /tmp/resolv.conf.d/resolv.conf.auto
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using nameserver #53
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using nameserver ::1#53
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using nameserver 100.100.1.1#53
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using nameserver 100.100.0.1#53
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using only locally-known addresses for test
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using only locally-known addresses for stbg.stanbicbank.co.zw
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using only locally-known addresses for powa.co.zw
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for media.discordapp.net
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for latency.discord.media
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for gateway.discord.gg
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for cdn.discordapp.com
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for cinema-rrs-eu.hicloud.com
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for discordstatus.com
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for discord.media
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for discord.gg
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for discord.com
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for discordapp.net
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for discordapp.com
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for updates.discord.com
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for v10.events.data.microsoft.com
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for s.youtube.com
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for ro.info.lgsmartad.com
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for ro.lgrecommends.lgappstv.com
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for settings-win.data.microsoft.com
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for m.yap.yahoo.com
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for mail.yahoo.com
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for app.melcloud.com
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for origin.com
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for speedapp.io
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for nvidia.tt.omtrdc.net
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for production.receiver.melcloud.com
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for static.twitchcdn.net
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for gql.twitch.tv
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for api.twitch.tv
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using standard nameservers for cvp.twitch.tv
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using 247545 more local addresses
Wed Apr 30 17:23:16 2025 daemon.info dnsmasq[1]: using 31 more nameservers
Wed Apr 30 17:23:17 2025 user.notice AdGuardHome[12298]: 2025/04/30 17:23:17.014218 [info] Received signal "terminated"
Wed Apr 30 17:23:17 2025 user.notice AdGuardHome[12298]: 2025/04/30 17:23:17.014322 [info] stopping AdGuard Home
Wed Apr 30 17:23:17 2025 user.notice AdGuardHome[12298]: 2025/04/30 17:23:17.014341 [info] stopping http server...
Wed Apr 30 17:23:17 2025 user.notice AdGuardHome[12298]: 2025/04/30 17:23:17.014953 [info] stopped http server
Wed Apr 30 17:23:17 2025 user.notice AdGuardHome[12298]: 2025/04/30 17:23:17.015145 [info] dnsproxy: stopping server
Wed Apr 30 17:23:17 2025 user.notice AdGuardHome[12298]: 2025/04/30 17:23:17.015593 [info] dnsproxy: stopped dns proxy server
Wed Apr 30 17:23:17 2025 user.notice AdGuardHome[12298]: 2025/04/30 17:23:17.020035 [info] stopped
Wed Apr 30 17:23:17 2025 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Wed Apr 30 17:23:17 2025 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 10 names
Wed Apr 30 17:23:17 2025 daemon.info dnsmasq[1]: read /tmp/hosts/odhcpd - 2 names
Wed Apr 30 17:23:17 2025 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Wed Apr 30 17:23:21 2025 kern.crit kernel: [  632.209396] protocol 86dd is buggy, dev br-lan
Wed Apr 30 17:23:21 2025 kern.crit kernel: [  632.213890] protocol 86dd is buggy, dev br-lan
Wed Apr 30 17:23:21 2025 kern.crit kernel: [  632.218428] protocol 86dd is buggy, dev br-lan
Wed Apr 30 17:23:21 2025 kern.crit kernel: [  632.223060] protocol 86dd is buggy, dev br-lan
Wed Apr 30 17:23:21 2025 kern.crit kernel: [  632.227649] protocol 86dd is buggy, dev br-lan
Wed Apr 30 17:23:21 2025 kern.crit kernel: [  632.232241] protocol 86dd is buggy, dev br-lan
Wed Apr 30 17:23:21 2025 kern.crit kernel: [  632.236710] protocol 86dd is buggy, dev br-lan
Wed Apr 30 17:23:21 2025 kern.crit kernel: [  632.241187] protocol 86dd is buggy, dev br-lan
Technical support for third-party plug-ins is not available for the time being.
Please try Google.
Is it possible that it is conflicting with ADG?
(or other plug-ins that have DNS services.)
In this case, does ADBlock work well?
I didn't use it if I saw these logs...
