Add an LED Brightness option?
The GL-iNet routers currently have an option to disable the LED (totally off).
But would it be possible to add an option to set the LED brightness? I'd like to keep the LED enabled to see that the device is on, but would love to make it less bright.
This is mostly a problem with the Opal GL-SFT1200, which has a large and pretty bright front LED.
It would be nice to see this option on all routers, as I have been using sticky notes for years to cut down the brightness.
They would likely need to be able to PWM the LEDs, which might not be possible. If it's annoyingly bright, a quick fix might be brightness adjust via Sharpie. Either external,or disassemble and paint the LEDs directly. Easily reversed without damage with rubbing alcohol.
