Is it possible to add an external antenna to an AR150 that came without one?
I can see the connector but from the diagrams it looks like this is used for something else?
Yes you can.We have a version with external ANT,the connector of inner ANT type is different from the external ANT type.
If you want to add an external ANT you should remove the J13 and weld an ANT if you have.
or a convenience way :BUY A NEW ONE WITH ex-ANT
ha ha …
Is it OK to cut the track going to the PCB antena just after J13, and put external antena on J13?
Other question: why J13? Factory testing?
Thanks
