For those who are tired to physically turn it off
#!/bin/sh
echo "This will simply add \"Shutdown\" button to your system menu. Do you want to continue? (y/n)"
read answer
case $answer in
[yY]* )
[nN]* )
echo "Installation cancelled."
exit
echo "Invalid input. Please answer with y or n."
exit
esac
APP_DIR="/usr/lib/lua/luci/controller/system"
mkdir -p "$APP_DIR"
cat > "$APP_DIR/shutdown.lua" <<EOF
module("luci.controller.system.shutdown", package.seeall)
function index()
entry({"admin", "system", "shutdown"}, call("action_shutdown"), _("Shutdown"), 90)
end
function action_shutdown()
luci.template.render("system/shutdown")
end
EOF
mkdir -p "$APP_DIR/view"
cat > "$APP_DIR/view/shutdown.htm" <<EOF
<form action="shutdown" method="post">
<button type="submit">Shutdown</button>
</form>
EOF
cat > "$APP_DIR/view/shutdown.lua" <<EOF
-- Safe shutdown command
os.execute("poweroff")
end
EOF
chmod +x "$APP_DIR/view/shutdown.lua"
echo "Shutdown button added successfully."
rm -- "$0"
