Hello!
The AmneziaVPN protocol was updated to AmneziaWG version 3.1 today. I have a Beryl AX (GL-MT3000), and I would like to see support for the AmneziaVPN 3.1 protocol in the next beta firmware.
Thank you in advance!
Hello!
I have devices where no VPN client can be installed (smart TV, consoles, streaming boxes), so the router is the only place to set up the tunnel. It also lets me manage routing in one spot instead of on every device. GL.iNet already supports AmneziaWG natively, the issue is just version compatibility between the firmware and the current protocol.
It is the server side installation on Windows that I find to be quite tricky to setup!
Thanks for the suggestion! We're already working on adding support for AmneziaWG 3.1.
Just wanted to let you know that we have added support for AmneziaWG 3.1 in MT3000 v4.11.1 stable and later versions.
