I've noticed that the Spitz AX (and presumably other GL.iNet cellular routers) does not have the correct APN built in for Verizon 5G Home Internet service: V5GA01INTERNET. Without this APN, the modem is unable to connect. Is this an APN option that could be added to the firmware so users don't have to manually input it?
You can already do this, create a custom profile in the gui and apply it.
ETA: This should help:
Yeah, I’m aware that it can be input manually, but there are a bunch of Verizon APNs already configured to be selectable by default and I figured it would be useful to add this one since it’s what they use for their 5G home internet service, which I’d imagine is a pretty common use case for GL.iNet’s devices ![]()
Hello, could you run the following AT command and help to get the related cellular info, we will consider to add it to the router:
AT+QENG="servingcell";+CGACT?;+CGDCONT?+CGCONTRDP
Thanks
Sure, these are the results:
+QENG: "servingcell","NOCONN","LTE","FDD",311,480,A82C03,296,5230,13,3,3,2B07,-77,-11,-48,20,12,100,-
+CGACT: 1,1
+CGACT: 2,1
+CGACT: 3,1
+CGACT: 4,0
+CGACT: 5,0
+CGACT: 6,0
+CGACT: 7,0
ERROR
This is on the 5/16 nightly build of the 4.8.0 firmware. I was having stability issues with 4.7 and earlier (including the current beta) 4.8 versions, but this version of the nightly seems to have resolved those stability issues.
Thanks for your feedback. Could you run this command again and share the output with us once again? There was a minor issue with my previous command.
AT+CGCONTRDP
Sure, here are the results of that command:
+CGCONTRDP: 1,5,"ims","38.0.16.18.16.75.5.168.159.228.195.251.241.134.193.221", "254.128.0.0.0.0.0.0.0.0.0.0.0.0.0.1", "32.1.72.136.0.100.255.0.6.32.0.13.0.0.0.0", "32.1.72.136.0.98.255.0.6.46.0.13.0.0.0.0","32.1.72.136.0.6.113.58.0.241.1.4.0.0.0.35","32.1.72.136.0.6.113.58.0.241.1.4.0.0.0.119"
+CGCONTRDP: 3,6,"V5GA01INTERNET","97.167.7.142",,"198.224.169.135","198.224.171.135"
OK
Got it. Many thanks
