Hi All
I’m brand new to VPN routers. I need to add a vpn subscription to the GL i net 300mbps router however I’m a newbie and feel a bit daunted and don’t know where to start! Any help appreciated
Thankyou
Hi All
Thankyou
If you will start with a VPN, i would recommend that you go directly to a wireguard based one. It will give you the latest security and the best speed. Mullvad and AzireVPN are the top providers for that ![]()
For OpenVPN, you can refer to this guide.
If you want to use WireGuard, upgrade to v3.0 testing firmware is recommended.
